Hosting a meno di $100/mese
Allora, come configuro il sito web?
E quali altri provider di hosting è possibile utilizzare?
There are instructions here: discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub
Good luck :slight_smile:
1 Mi Piace
So I have to host with DigitalOcean?
Digital Ocean is the most popular choice, yes. But there are hundreds of equivalents alternatives. Other popular ones are Vultr, Linode, AWS LightSail, Scaleway, Hetzner.
Would I be able to host with repl.it?
and do you know why hosting is like 100$ a month?
I guess it suits people with money but limited time or technical expertise, and companies who won’t quibble over price in exchange for a contract promising uptime, support etc.
Probably Not
That’s the price for getting your hosting from CDCK. Discourse itself is free & open source so you always have the choice to self host Discourse on a VPS
1 Mi Piace
@itsbhanusharma Is it possible? Or what hosting software could I use?
That’s not digitalOcean?
I’d assume you meant hosting service. You can choose any hosting service that offers VPS with specs as mentioned in the install doc.
There were some recommendations made by falco
I would add that not all VPS providers are equal. Make sure the VPS you use is KVM, and not OpenVZ, or Discourse will not install.
If (like me) you aren’t hugely experienced then just go with Digital Ocean and Mailgun, as recommended.
4 Mi Piace
What part of the docs made you think you needed to use Digital Ocean? They’re one example among many of providers who will give you a virtual Linux server; other examples were mentioned up-topic. I’ve been using Contabo for a while (for Discourse and other sites) and been happy with them.
Now, if you don’t understand “these steps will work on any Docker-compatible cloud provider or local server”, self-hosting your own Discourse instance may be a bit beyond you at this time.
2 Mi Piace
If you need lower priced hosting options to fit your budget, you can look into literatecomputing.com (one time setup fee, plus $5/month) or communiteq.com for example.
6 Mi Piace
I use communiteq.com for hosting my forum. I am happy to say that it was exactly what I was looking for. It is much cheaper than Discourse itself, easy, and the support there is phenomenal! I almost always get a reply in under 6 hours!
5 Mi Piace
Con l’hosting offerto direttamente da Discourse, i prezzi sono particolarmente orientati a clienti commerciali o aziendali che necessitano di forum che funzionino semplicemente senza doverci pensare, e includono un supporto di livello enterprise.
Communiteq offre un hosting di buona qualità a un prezzo di ingresso più basso, eliminando la necessità di gestire un server.
In alternativa, il servizio di installazione precedentemente menzionato fornito da Literate Computing rappresenta un ottimo rapporto qualità-prezzo: non l’ho utilizzato personalmente, ma ho capito che include non solo la configurazione iniziale di Discourse, ma anche la corretta sicurezza del server Linux, aspetto fondamentale. 100,00 $ è un ottimo prezzo per questo tipo di servizio.
Se non hai esperienza con Linux, è davvero meglio affidarsi a uno dei servizi menzionati, poiché errori futuri potrebbero costare molto di più.
Ovviamente, se desideri imparare, puoi assolutamente provare a farlo da solo: qualsiasi provider VPS che a) soddisfi le specifiche e b) utilizzi KVM o un’altra piattaforma di virtualizzazione che supporti Docker dovrebbe fare al caso tuo.
4 Mi Piace
Quanto costano le email? Offrite l’accesso tramite social network?
1 Mi Piace
Le email e tutto il resto sono inclusi, ma puoi utilizzare un indirizzo Gmail (o qualsiasi altro dominio) se preferisci. Per configurare l’accesso tramite social, devi procedere esattamente come farebbe per qualsiasi altra community Discourse, utilizzando una chiave API. Tuttavia, puoi aggiungere Google e molte altre grandi aziende come desideri.
2 Mi Piace
Bene. C’è un problema dovuto a indirizzi IP condivisi e spam?
1 Mi Piace
No.
2 Mi Piace
