색상 팔레트 설정이 반영되지 않습니다
I have a new discourse installation and created scaffolding for a new theme. First thing was I edited the color scheme to use a scheme called Flexoki. You can see here:
I’ve added and selected the theme via GitHub on my discourse instance but none of the color settings are reflected, instead I just see the default colors listed, for both Flexoki Light and Dark. Any help troubleshooting?
Yep so there’s a few things to check first:
  1. Make sure your theme has that particular color palette selected:
  1. If that setting is correct but it’s still showing the wrong color palette, make sure that your profile settings doesn’t have the wrong color palette selected:
thanks, neither of those are the issue. As the screenshot shows, the ui is showing the flexoki theme as being just the default discourse colors. somehow the palette is not being interpreted at all
내가 잘못 본 것일 수도 있습니다. 하지만 앞뒤로 움직여 보면 업로드하신 색상 팔레트가 light 의 복사본처럼 보입니다.
Customization > Theme 로 이동하여 다른 모양의 팔레트를 가진 항목을 선택하고, 해당 색상 팔레트로 전환해 보세요.
Ah, I see what you mean now. So Discourse is not reading these colors:
"color_schemes": {
    "Flexoki Light": {
      "primary": "#100F0F",
      "secondary": "#FFFCF0",
      "tertiary": "#205EA6",
      "quaternary": "#AF3029",
      "header_background": "#F2F0E5",
      "header_primary": "#6F6E69",
      "highlight": "#ECCB60",
      "danger": "#AF3029",
The issue is above – it’s not using the colors listed in the file^^
Is there maybe an issue then with the file layout? Causing it to defaults?
It might be best to simply create a new color palette within Discourse entering these values rather than importing the theme.git
I looked at the syntax of the file. In my previous color palette scheme, it doesn’t have # in each hexadecimal string.
If you change each of the hexadecimal strings to not have # at the start, I think it might parse correctly.
This is also the case in the example guide for Discourse color schemes:
   "name" : "Solarized",
   "about_url" : "https://github.com/SamSaffron/discourse-solarized",
   "license_url": "https://github.com/SamSaffron/discourse-solarized/blob/master/LICENSE",
   "color_schemes": {
      "Solarized Light": {
        "primary": "586E75",
        "secondary": "EEE8D5",
        "tertiary": "268BD2",
        "quaternary": "CB4B16",
        "header_background": "002B36",
        "header_primary": "93A1A1",
        "highlight": "B58900",
        "danger": "CB4B16",
        "success": "859900",
        "love": "DC322F"
ah!! thank you! will try this fix shortly, seems like the sure answer.
