Using Transformers to customize client-side values and behavior
Discourse core includes a number of “transformer” hooks which can be used to customize client behavior. These fall into two categories:
  • Value Transformers take an output from Discourse core, and optionally modify it, or replace it with something else
  • Behavior Transformers can replace a particular piece of logic in Discourse core, and optionally call the original implementation.
Each transformer hook is referenced by a name, and multiple plugins/themes can register transformers against the same hook.
Value Transformers
Value transformers can be registered using api.registerValueTransformer:
registerValueTransformer => boolean
Param Type Description
transformerName string the name of the transformer
valueCallback function({value, context}) callback to be used to transform the value
The valueCallback will be passed two named arguments: the original value, and a context object. It should return the transformed value. Or, if no transformation is required, it should return the original value.
Callbacks can access the provided context for the current transformer hook, or they can reference other data sources. Many value transformers are executed in autotracking contexts, which means that referencing reactive state will cause the transformer to be automatically re-evaluated when that state changes.
For example, to modify the link URL of the logo on mobile devices:
api.registerValueTransformer("home-logo-href", ({ value, context }) => {
  const site = api.container.lookup("service:site");
  if (site.mobileView) {
    return "/latest";
  } else {
    return value;
Behavior transformers are similar, but instead of receiving and returning a value, they wrap some original behavior, and can optionally call the original implementation.
registerBehaviorTransformer => boolean
behaviorCallback function({next, context}) callback to be used to transform or override the behavior
The behaviorCallback is passed two named arguments. next is a function which can optionally be called to run the original behavior. context contains extra information which may be useful.
For example, if you wanted to limit infinite loading to 100 topics:
api.registerBehaviorTransformer(
  "discovery-topic-list-load-more",
  ({ next, context }) => {
    const topicList = context.model;
    if (topicList.topics.length > 100) {
      alert("Not loading any more");
    } else {
      next();
Multiple registered transformers
If multiple transformers are registered against a single name, then they will be run in order of registration. The input to valueTransformers will be the value returned by the previous transformer. The next() function passed to behaviorTransformers will call the remaining transformers in the chain.
Finding Transformers
At the moment there is no centralized documentation for transformers. However, a list of all core transformers can be found in the code here. You can then search for those names in the core codebase to find where they’re called, the context/value, and the expected return type.
Introducing new Transformers
To introduce new transformers, the name first needs to be added to the registry. In core, add it to lib/transformer/registry.js.
To introduce a new transformer via a theme or plugin, create a pre-initializer and register the name via the relevant API:
// .../discourse/pre-initializers/my-transformer.js
export default {
  before: "freeze-valid-transformers",
  initialize() {
    withPluginApi((api) => {
      api.addValueTransformerName("my-value-transform");
      api.addBehaviorTransformerName("my-behavior-transform");
To apply the transformer to some value or behavior, import the associated apply function and use it anywhere in your code:
import {
  applyValueTransformer,
  applyBehaviorTransformer,
} from "discourse/lib/transformer";
const context = { bestForumSoftware: "Discourse" };
// Value Transformer
const originalValue = "Hello";
const transformedValue = applyValueTransformer(
  "my-value-transform",
  originalValue,
  context
// Behavior Transformer
applyBehaviorTransformer(
  "my-behavior-transformer",
    alert("This is the core implementation");
  context
This document is version controlled - suggest changes on github.
10 Mi Piace
Ho aperto una PR per modificare i link al registro Transformers affinché provengano dalla directory frontend invece che dalla directory app/assets.
EDIT: Unito! Grazie @david!
1 Mi Piace
