Is an automation like this possible with Discourse AI today?
The discussion explores whether an automation workflow—used to generate product announcement banners from draft content—can be achieved natively within Discourse AI. jordan-violet describes a process using n8n to extract product details, summarize content via an LLM, and generate banners with tools like Storyset and image APIs. sam suggests Discourse AI’s Designer persona, powered by GPT Image 1, could handle similar tasks using custom personas and REST APIs for image generation, referencing a JavaScript example for integrating flux image generation. jordan-violet asks whether Discourse AI should parse post content into parameters or if the LLM must handle it, and sam confirms tools can accept post IDs directly. jordan-violet requests documentation, while sam notes that Discourse AI’s API is still evolving, with ongoing updates to its functionality.
There’s is a task we do today that I’ve been able to make pretty good progress in automating using n8n, but I’m wondering if it’s possible with Discourse natively.
We have a draft category where product marketing managers draft product announcements to be sent out about their products. When they create that draft, we look at the product name, the version, if it’s a major/minor/patch release. We also take the body of their announcement content and summarize it with a LLM for a 4-7 word description of the content.
We then use that to create the announcement banner in Adobe, like so:
I feel as though this could be done by an LLM and some traditional logic:
  • The background is just one hue per announcement type and there are four variations of each color—we just randomly select one.
  • The product name and version are entered into the boxes at the top
  • The description in the body middle-center there
  • We use https://storyset.com/ to whip up a quick illustration to put on the right.
I feel I have a good approach to doing this with n8n, but wonder if it could be done natively with Discourse AI and other tools?
The Designer persona using the excellent new GPT Image 1 model is capable of doing stuff like this:
I think you could wire something up using custom presona and using the right tools to achieve a lot of this, for sure.
Note for custom tool usage, as long as there are proper REST APIs you can integrate easily, for example this is how I integrate with flux image generation:
const apiKey = "password";
const model = "black-forest-labs/FLUX.1.1-pro";
let prompt;
function invoke(params) {
  let seed = parseInt(params.seed);
  if (!(seed > 0)) {
    seed = Math.floor(Math.random() * 1000000) + 1;
  let height = parseInt(params.height);
  if (!height || height < 256 || height > 1440) {
      height = 768;
  let width = parseInt(params.width);
  if (!width || width < 256 || width > 1440) {
      width = 1024;
  width = width - (width % 32);
  height = height - (height %32);
  prompt = params.prompt;
  const negative_prompt = params.negative_prompt || "";
  const body = {
    model: model,
    prompt: prompt,
    width: width,
    height: height,
    steps: 10,
    n: 1,
    seed: seed,
    negative_prompt: negative_prompt,
    response_format: "b64_json",
  const result = http.post("https://api.together.xyz/v1/images/generations", {
    headers: {
      "Authorization": `Bearer ${apiKey}`,
      "Content-Type": "application/json",
    body: JSON.stringify(body),
  if (result.status !== 200) {
      return { error: true, body: result.body };
  const base64Image = JSON.parse(result.body).data[0].b64_json;
  const image = upload.create("generated_image.png", base64Image);
  const raw = `
![${prompt}](${image.short_url})
  if (!params.show_to_user === false) {
     chain.setCustomRaw(raw);
  return { result: "Image generated successfully", prompt: prompt, url: image.url, seed: seed, negative_prompt: negative_prompt };
function details() {
  return prompt;
You can see the HTTP post and the parsing of the base 64 image in the sample.
If given a post body, does the burden for turning content from that body into valid parameters fall on Discourse AI to read the content and then create the request object? Or should the raw content be passed onto the tool and the burden for an LLM parsing that for the necessary data to construct a proper input for its API call exist there?
Yes in that case the tool has an api already for reading posts so you can just pass an id in
Would you be able to point me to the docs for this by chance?
Sorry for the delayed reply here, it is tricky, our documentation is evolving and the API surface is growing weekly.
This kind of technique provides some accurate up to date mileage, but I think we need to wait a bit for all the API to stablize prior to setting stuff in stone:
