Can the images uploaded to /admin/config/logo be SVG? Or just jpg and png?
SVG should work for site logo, but you will likely want a different format for email digest digest logo setting. also, you might have to add svg file type to Authorized extensions admin setting.
Thanks! Worked like a charm and on mobile, SVG looks so much better.
I added the SVG to the Authorized extensions for staff only, as I don’t need users to upload SVGs.
I ended up just changing the Primary Logo. Everything else is png.
