No matter how many times I try to update, I always get Sorry, there was an error updating Discourse. Please check the logs below. when updating via the browser. I always have to rely on Terminal and that isn’t good, because then I will always have to have my forum down for like 30 minutes.
If anyone can help me here, that would be appreciated.
Errors:
Summary
*** Please be patient, next steps might take a while ***
Cycling Unicorn, to free up memory
Restarting unicorn pid: 603
Waiting for Unicorn to reload.
Waiting for Unicorn to reload..
Waiting for Unicorn to reload...
Waiting for Unicorn to reload....
Waiting for Unicorn to reload.....
Waiting for Unicorn to reload......
Waiting for Unicorn to reload.......
Waiting for Unicorn to reload........
Waiting for Unicorn to reload.........
Waiting for Unicorn to reload..........
Waiting for Unicorn to reload...........
Waiting for Unicorn to reload............
Waiting for Unicorn to reload.............
Waiting for Unicorn to reload..............
Waiting for Unicorn to reload...............
Waiting for Unicorn to reload................
Waiting for Unicorn to reload.................
Waiting for Unicorn to reload..................
Waiting for Unicorn to reload...................
Waiting for Unicorn to reload....................
Waiting for Unicorn to reload.....................
Waiting for Unicorn to reload......................
Waiting for Unicorn to reload.......................
Waiting for Unicorn to reload........................
Waiting for Unicorn to reload.........................
Waiting for Unicorn to reload..........................
Waiting for Unicorn to reload...........................
Waiting for Unicorn to reload............................
Waiting for Unicorn to reload.............................
Waiting for Unicorn to reload..............................
Waiting for Unicorn to reload...............................
$ cd /var/www/discourse && git reset --hard HEAD@{upstream}
HEAD is now at fe1b1edba FIX: removes + from RTE toggle tooltip (#33542)
$ bundle install --retry 3 --jobs 4
Bundle complete! 143 Gemfile dependencies, 190 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
3 installed gems you directly depend on are looking for funding.
Run `bundle fund` for details
$ if [ -f yarn.lock ]; then yarn install; else CI=1 pnpm install; fi
Scope: all 16 workspace projects
Lockfile is up to date, resolution step is skipped
Already up to date
Done in 9.1s using pnpm v9.15.6
$ LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all
discourse-adplugin is already at latest compatible version
discourse-categories-suppressed is already at latest compatible version
discourse-doc-categories is already at latest compatible version
Invalid version list in /var/www/discourse/plugins/discourse-landing-pages
discourse-landing-pages is already at latest compatible version
discourse-solved is already at latest compatible version
docker_manager is already at latest compatible version
$ SKIP_POST_DEPLOYMENT_MIGRATIONS=1 bundle exec rake multisite:migrate
Multisite migrator is running using 1 threads
Migrating default
Seeding default
*** Bundling assets. This will take a while ***
$ bundle exec rake themes:update assets:precompile
Updating themes with concurrency: 10
[db:default] 'New Topic Header Button' - checking...
[db:default] 'New Topic Header Button' - up to date
[db:default] 'Category Banners' - checking...
[db:default] 'Category Banners' - up to date
[db:default] 'Clickable Topic' - checking...
[db:default] 'Clickable Topic' - up to date
[db:default] 'Tag Banners' - checking...
[db:default] 'Tag Banners' - up to date
[db:default] 'Breadcrumb Links' - checking...
[db:default] 'Breadcrumb Links' - up to date
[db:default] 'Welcome Link Banner' - checking...
[db:default] 'Welcome Link Banner' - up to date
[db:default] 'Tag Icons' - checking...
[db:default] 'Tag Icons' - up to date
[db:default] 'Social Share' - checking...
[db:default] 'Social Share' - up to date
[db:default] 'Navigation Menu Display Control' - checking...
[db:default] 'Navigation Menu Display Control' - up to date
[db:default] 'DiscoTOC' - checking...
Node.js heap_size_limit is less than 2048MB. Setting --max-old-space-size=2048 and CHEAP_SOURCE_MAPS=1
Existing build is not reusable.
- Existing: {"ember_env"=>"production", "core_tree_hash"=>"c71c1ad482ff7f24c3ad3a76d5a521861f29e1fb"}
- Current: {"ember_env"=>"production", "core_tree_hash"=>"d026d5621e9421eaf67123aab7361a44f0fa9c31"}
Running full core build...
Building
Environment: production
The setting 'staticAddonTrees' will default to true in the next version of Embroider and can't be turned off. To prepare for this you should set 'staticAddonTrees: true' in your Embroider config.
The setting 'staticAddonTestSupportTrees' will default to true in the next version of Embroider and can't be turned off. To prepare for this you should set 'staticAddonTestSupportTrees: true' in your Embroider config.
building...
...[ConfigLoader]
...[Babel: @embroider/macros > applyPatches]
...[Babel: pretty-text > applyPatches]
...[Babel: @ember/legacy-built-in-components > applyPatches]
...[Babel: ember-source > applyPatches]
[BABEL] Note: The code generator has deoptimised the styling of /var/www/discourse/app/assets/javascripts/discourse/ember/ember-template-compiler.js as it exceeds the max of 500KB.
[BABEL] Note: The code generator has deoptimised the styling of /var/www/discourse/app/assets/javascripts/discourse/ember/ember.js as it exceeds the max of 500KB.
...[Babel: @glimmer/component > applyPatches]
...[Babel: @ember/render-modifiers > applyPatches]
...[Babel: dialog-holder > applyPatches]
...[Babel: ember-this-fallback > applyPatches]
...[Babel: ember-buffered-proxy > applyPatches]
...[Babel: ember-cache-primitive-polyfill > applyPatches]
...[Babel: float-kit > applyPatches]
...[Babel: select-kit > applyPatches]
...[@embroider/compat/app]
...[@embroider/webpack]
undefined
ERR_PNPM_RECURSIVE_EXEC_FIRST_FAIL Command was killed with SIGKILL (Forced termination): ember build -prod
/var/www/discourse/script/assemble_ember_build.rb:103:in `system': Command failed with exit 1: pnpm (RuntimeError)
from /var/www/discourse/script/assemble_ember_build.rb:103:in `<main>'
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:211:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:112:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:44:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:44:in `block in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/execution_wrapper.rb:91:in `wrap'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:70:in `conditional_executor'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command/base.rb:178:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor.rb:538:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command/base.rb:73:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:71:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:149:in `with_argv'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:69:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands.rb:18:in `<main>'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:69:in `require'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:69:in `block (2 levels) in replace_require'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bootsnap-1.18.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
Spinning up 1 Unicorn worker(s) that were stopped initially
