Fout bij het upgraden van discourse-instantie naar 15 feb 2022
Users balupton and itsbhanusharma encountered failures upgrading their Discourse instances to the February 15, 2022 release, primarily due to out-of-memory (OOM) errors during asset precompilation, signaled by exit code 137. The failure occurred during rake themes:update assets:precompile, often while Ember CLI was building assets. JammyDodger suggested checking logs for theme/component issues and restarting the app to recover. itsbhanusharma proposed setting EMBER_CLI_PROD_ASSETS: 0 as a workaround, which balupton confirmed resolved the issue. However, david warned this workaround will be removed soon and emphasized the need for at least 1GB RAM + 2GB swap. Memory diagnostics via free showed critically low available memory (e.g., 9960 KiB), even on a 4GB RAM + 2GB swap server, which itsbhanusharma later resolved with a reboot, restoring healthy memory usage. RGJ and Ed_S highlighted that insufficient virtual memory (RAM + swap) was the root cause, especially during rebuilds. Ed_S explained that setting vm.overcommit_memory = 1 can help by allowing the kernel to overcommit memory, which is useful for Redis and fork-heavy processes during upgrades. balupton added swap manually and sought clarification on the overcommit_memory setting, which RGJ linked to Redis, while Ed_S clarified its broader impact on virtual memory pressure. The consensus is that sufficient RAM + swap is critical, and the overcommit_memory tweak can mitigate OOM during rebuilds on resource-constrained systems.
Upgrading from Commits · discourse/discourse · GitHub to the latest has caused the site to go down, here is notable segments of the logs:
I, [2022-02-15T05:27:48.995821 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2022-02-15T05:27:48.997476 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2022-02-15T05:27:48.998553 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2022-02-15T05:27:49.003918 #1]  INFO -- : > sleep 5
2022-02-15 05:27:49.151 UTC [41] LOG:  starting PostgreSQL 13.5 (Debian 13.5-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2022-02-15 05:27:49.152 UTC [41] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2022-02-15 05:27:49.152 UTC [41] LOG:  listening on IPv6 address "::", port 5432
2022-02-15 05:27:49.162 UTC [41] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2022-02-15 05:27:49.184 UTC [44] LOG:  database system was shut down at 2022-02-15 00:12:32 UTC
2022-02-15 05:27:49.209 UTC [41] LOG:  database system is ready to accept connections
I, [2022-02-15T05:27:54.013563 #1]  INFO -- :
I, [2022-02-15T05:27:54.015179 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2022-02-15 05:27:54.259 UTC [54] postgres@postgres ERROR:  database "discourse" already exists
2022-02-15 05:27:54.259 UTC [54] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2022-02-15T05:27:54.270626 #1]  INFO -- :
I, [2022-02-15T05:27:54.272627 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2022-02-15 05:27:54.425 UTC [58] postgres@discourse ERROR:  role "discourse" already exists
2022-02-15 05:27:54.425 UTC [58] postgres@discourse STATEMENT:  create user discourse;
I, [2022-02-15T05:27:54.431376 #1]  INFO -- :
I, [2022-02-15T05:27:54.431915 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2022-02-15T05:27:54.533010 #1]  INFO -- : GRANT
I, [2022-02-15T05:27:55.303411 #1]  INFO -- : > echo redis installed
I, [2022-02-15T05:27:55.310858 #1]  INFO -- : redis installed
I, [2022-02-15T05:27:55.312551 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2022-02-15T05:27:55.323276 #1]  INFO -- : logfile ""
I, [2022-02-15T05:27:55.324362 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2022-02-15T05:27:55.329352 #1]  INFO -- : > sleep 10
102:C 15 Feb 2022 05:27:55.343 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
102:C 15 Feb 2022 05:27:55.343 # Redis version=6.2.6, bits=64, commit=00000000, modified=0, pid=102, just started
102:C 15 Feb 2022 05:27:55.343 # Configuration loaded
102:M 15 Feb 2022 05:27:55.346 * monotonic clock: POSIX clock_gettime
102:M 15 Feb 2022 05:27:55.349 * Running mode=standalone, port=6379.
102:M 15 Feb 2022 05:27:55.350 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
102:M 15 Feb 2022 05:27:55.350 # Server initialized
102:M 15 Feb 2022 05:27:55.350 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
102:M 15 Feb 2022 05:27:55.352 * Loading RDB produced by version 6.2.6
102:M 15 Feb 2022 05:27:55.352 * RDB age 18923 seconds
102:M 15 Feb 2022 05:27:55.352 * RDB memory usage when created 133.51 Mb
102:M 15 Feb 2022 05:27:55.912 # Done loading RDB, keys loaded: 7294, keys expired: 127.
102:M 15 Feb 2022 05:27:55.912 * DB loaded from disk: 0.560 seconds
102:M 15 Feb 2022 05:27:55.912 * Ready to accept connections
I, [2022-02-15T05:28:05.336548 #1]  INFO -- :
I, [2022-02-15T05:28:05.337696 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2022-02-15T05:28:05.349534 #1]  INFO -- : thpoff is installed!
I, [2022-02-15T05:28:05.349959 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2022-02-15T05:28:05.496038 #1]  INFO -- :
I, [2022-02-15T05:28:05.496604 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2022-02-15T05:28:05.617847 #1]  INFO -- :
I, [2022-02-15T05:28:05.618268 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2022-02-15T05:28:05.754370 #1]  INFO -- :
I, [2022-02-15T05:28:05.755864 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2022-02-15T05:28:05.763371 #1]  INFO -- :
I, [2022-02-15T05:28:05.773372 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2022-02-15T05:28:05.785161 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2022-02-15T05:28:05.801026 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2022-02-15T05:28:05.816469 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2022-02-15T05:28:05.828667 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2022-02-15T05:28:05.841176 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2022-02-15T05:28:05.841464 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2022-02-15T05:28:05.842241 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2022-02-15T05:28:05.847862 #1]  INFO -- : > cd /var/www/discourse && git reset --hard
130:C 15 Feb 2022 05:28:05.853 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
130:C 15 Feb 2022 05:28:05.854 # Redis version=6.2.6, bits=64, commit=00000000, modified=0, pid=130, just started
130:C 15 Feb 2022 05:28:05.855 # Configuration loaded
130:M 15 Feb 2022 05:28:05.857 * monotonic clock: POSIX clock_gettime
130:M 15 Feb 2022 05:28:05.858 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
130:M 15 Feb 2022 05:28:05.859 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (30947/30947), done.
I, [2022-02-15T05:28:13.624544 #1]  INFO -- : HEAD is now at e1367cde I18N: Improve copy on blocked words error messages (#15741)
I, [2022-02-15T05:29:36.205328 #1]  INFO -- : > cd /var/www/discourse && [ ! -d 'node_modules' ] || su discourse -c 'yarn install --production && yarn cache clean'
warning Resolution field "lodash@4.17.21" is incompatible with requested version "lodash@4.17.15"
warning " > @mixer/parallel-prettier@2.0.1" has unmet peer dependency "prettier@^2.0.0".
I, [2022-02-15T05:33:01.692668 #1]  INFO -- : yarn install v1.22.17
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
[4/5] Linking dependencies...
[5/5] Building fresh packages...
$ yarn --cwd app/assets/javascripts/discourse
[1/4] Resolving packages...
[2/4] Fetching packages...
[3/4] Linking dependencies...
[4/4] Building fresh packages...
success Saved lockfile.
Done in 133.99s.
Done in 195.02s.
yarn cache v1.22.17
success Cleared cache.
Done in 9.35s.
I, [2022-02-15T05:33:01.697905 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2022-02-15T05:33:12.324517 #1]  INFO -- : discourse-github is already at latest compatible version
discourse-solved is already at latest compatible version
discourse-chat is already at latest compatible version
I, [2022-02-15T05:33:12.325695 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
102:M 15 Feb 2022 05:33:37.418 * 100 changes in 300 seconds. Saving...
102:M 15 Feb 2022 05:33:37.423 * Background saving started by pid 1143
1143:C 15 Feb 2022 05:33:38.349 * DB saved on disk
1143:C 15 Feb 2022 05:33:38.352 * RDB: 2 MB of memory used by copy-on-write
102:M 15 Feb 2022 05:33:38.429 * Background saving terminated with success
I, [2022-02-15T05:33:38.994811 #1]  INFO -- : gem install sawyer -v 0.8.2 -i /var/www/discourse/plugins/discourse-github/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Successfully installed sawyer-0.8.2
1 gem installed
gem install octokit -v 4.21.0 -i /var/www/discourse/plugins/discourse-github/gems/2.7.5 --no-document --ignore-dependencies --no-user-install
Successfully installed octokit-4.21.0
1 gem installed
== 20220214224506 ResetCustomEmojiPostBakesVersionSecureFix: migrating ========
== 20220214224506 ResetCustomEmojiPostBakesVersionSecureFix: migrated (0.0099s)
== 20220214233625 AddBounceErrorCodeToEmailLog: migrating =====================
-- add_column(:email_logs, :bounce_error_code, :string, {:null=>true})
   -> 0.0103s
== 20220214233625 AddBounceErrorCodeToEmailLog: migrated (0.0121s) ============
I, [2022-02-15T05:33:38.996639 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
- Building
- Building
- building...
102:M 15 Feb 2022 05:38:39.069 * 100 changes in 300 seconds. Saving...
102:M 15 Feb 2022 05:38:39.080 * Background saving started by pid 1213
1213:C 15 Feb 2022 05:38:39.863 * DB saved on disk
1213:C 15 Feb 2022 05:38:39.867 * RDB: 2 MB of memory used by copy-on-write
102:M 15 Feb 2022 05:38:39.883 * Background saving terminated with success
[WARN] (broccoli-terser-sourcemap) Minifying "assets/discourse.js" took: 35001ms (more than 20,000ms)
Killed
error Command failed with exit code 137.
I, [2022-02-15T05:52:50.058283 #1]  INFO -- : yarn run v1.22.17
$ /var/www/discourse/app/assets/javascripts/node_modules/.bin/ember build -prod
WARNING: Node v16.13.2 is not tested against Ember CLI on your platform. We recommend that you use the most-recent "Active LTS" version of Node.js. See https://git.io/v7S5n for details.
DEPRECATION: The integration of jQuery into Ember has been deprecated and will be removed with Ember 4.0. You can either opt-out of using jQuery, or install the `@ember/jquery` addon to provide the jQuery integration. Please consult the deprecation guide for further details: https://emberjs.com/deprecations/v3.x#toc_jquery-apis
Environment: production
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
I, [2022-02-15T05:52:50.072549 #1]  INFO -- : Terminating async processes
I, [2022-02-15T05:52:50.072816 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 41
I, [2022-02-15T05:52:50.073275 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 102
102:signal-handler (1644904370) Received SIGTERM scheduling shutdown...
2022-02-15 05:52:50.074 UTC [41] LOG:  received fast shutdown request
2022-02-15 05:52:50.090 UTC [41] LOG:  aborting any active transactions
2022-02-15 05:52:50.096 UTC [41] LOG:  background worker "logical replication launcher" (PID 50) exited with exit code 1
2022-02-15 05:52:50.102 UTC [45] LOG:  shutting down
102:M 15 Feb 2022 05:52:50.118 # User requested shutdown...
102:M 15 Feb 2022 05:52:50.120 * Saving the final RDB snapshot before exiting.
2022-02-15 05:52:50.248 UTC [41] LOG:  database system is shut down
102:M 15 Feb 2022 05:52:51.075 * DB saved on disk
102:M 15 Feb 2022 05:52:51.076 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 1144 exit 137>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
1716fd9590e21cdfdaccea0ac6faabd133a6423e1a24ef3b3b5be0e68ce422c9
Running discourse-doctor now, and gathering more detailed logs.
This is the upgrade script I made and have been using successfully for a year or more:
https://github.com/balupton/dotfiles/blob/master/commands/discourse-upgrader
There should be a more specific error above ‘FAILED’ if you scroll up.
It looks like it doesn’t like a theme/component though. You may want to ./launcher restart app to bring back the pre-rebuild version so you can use the regular UI to disable the one in question before attempting another upgrade. Did scrolling up give you a clue as to which one?
The only siginficant log from brew doctor was these:
I, [2022-02-15T06:14:34.823778 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
- Building
- Building
- building...
Killed
I, [2022-02-15T06:25:24.689000 #1]  INFO -- : yarn run v1.22.17
I, [2022-02-15T06:25:24.701625 #1]  INFO -- : Terminating async processes
I, [2022-02-15T06:25:24.702927 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
I, [2022-02-15T06:25:24.703765 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 103
103:signal-handler (1644906324) Received SIGTERM scheduling shutdown...
2022-02-15 06:25:24.710 UTC [42] LOG:  received fast shutdown request
2022-02-15 06:25:24.741 UTC [42] LOG:  aborting any active transactions
103:M 15 Feb 2022 06:25:24.777 # User requested shutdown...
103:M 15 Feb 2022 06:25:24.777 * Saving the final RDB snapshot before exiting.
2022-02-15 06:25:24.796 UTC [42] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2022-02-15 06:25:24.797 UTC [46] LOG:  shutting down
2022-02-15 06:25:25.023 UTC [42] LOG:  database system is shut down
103:M 15 Feb 2022 06:25:26.383 * DB saved on disk
103:M 15 Feb 2022 06:25:26.385 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 1146 exit 137>
a1a2ad7dab631a87852f269d0de01bee80aea384be8a94ba4eb555f1fa5d9094
==================== END REBUILD LOG ====================
Failed to rebuild app.
Checking your domain name . . .
Connection to discuss.bevry.me succeeded.
You should probably remove any non-standard plugins and rebuild.
Attempting to restart existing container. . .
x86_64 arch detected.
starting up existing container
+ /usr/bin/docker start app
Error response from daemon: driver failed programming external connectivity on endpoint app (924d10c5f09f04b43e96bd6d1a4a13945cd86ebbb12821a4943914538821b856): Error starting userland proxy: listen tcp 0.0.0.0:443: bind: address already in use
Error: failed to start containers: app
Failed to restart the container.
I’ve updated the OP to include more of the original logs.
Rerunning discourse-doctor again, as it failed because wget was missing. Will post the full log once that is done.
I can confirm this, I’ve tried this on 3 Different instances and builds are getting failed after reaching the below state.
I, [2022-02-15T07:09:36.714521 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
I, [2022-02-15T07:09:46.598212 #1]  INFO -- :
I, [2022-02-15T07:09:46.599983 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
- Building
- Building
- building...
Killed
I, [2022-02-15T07:30:11.622116 #1]  INFO -- : Checking 'Easy Footer' for 'default'... up to date
Checking 'Discourse Loading Slider' for 'default'... up to date
Checking 'discourse-search-banner' for 'sandbox'... up to date
Checking 'discourse-category-sidebars' for 'sandbox'... up to date
Checking 'Hide Users Column' for 'sandbox'... up to date
Checking 'discourse-sidebar-nav' for 'sandbox'... up to date
Checking 'Dracula Theme' for 'sandbox'... up to date
Checking 'discourse-buttons' for 'tekduke'... yarn run v1.22.17
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 1034 exit 137>
49ed46d025f5fe0a3de022b073b507cc3d94f74f96a60fe2d55042d413def454
it looks like ember CLI related issue.
hey @balupton could you try changing EMBER_CLI_PROD_ASSETS: 0 and try rebuilding again? I have at least 1 successful rebuild after the above change.
These seem to be the only relevant logs that indicate anything is wrong:
I, [2022-02-15T07:15:48.531001 #1]  INFO -- : > cd /var/www/discourse && [ ! -d 'node_modules' ] || su discourse -c 'yarn install --production && yarn cache clean'
I, [2022-02-15T07:19:45.453691 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
- Building
- Building
- building...
Killed
I, [2022-02-15T07:31:39.549100 #1]  INFO -- : yarn run v1.22.17
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 1145 exit 137>
a262c461f2ae24390cb1397df309c44738cdc2688483d5fb7d52a3fde3155409
Will try that, how do I apply it?
Nevermind, found it:
Will give it a go now.
Looking at the changelog:
I wonder if it is this:
https://github.com/discourse/discourse/pull/15919
As one of the logs was:
103:M 15 Feb 2022 06:54:18.720 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
Out of memory.
Make sure you have enough (virtual) memory. 1GB of memory and 2GB of swap is probably too low nowadays for a rebuild.
Yep, it worked.
vim /var/discourse/containers/app.yml
env:
  ## Workaround for: https://meta.discourse.org/t/failed-to-upgrade-discourse-instance-to-feb-15-2022/218204/7?u=balupton
with discourse now successfully running, top is currently returning:
KiB Mem : **2041324** total, **287808** free, **1033300** used, **720216** buff/cache
KiB Swap: **0** total, **0** free, **0** used. **581308** avail Mem
It is the VC1S server from Scaleway:
https://serverscope.io/providers/scaleway/plans/vc1s
Would doing the suggestion in:
Also solve it?
The VPS has 4GB RAM and 2GB Swap.
You need to add some swap. Looks like you have plenty of disk, so you could add 2G or even 3G for safety.
The discourse standard setup should, I think, have already set up the swap for you. Perhaps see Create a swapfile for your Linux server
And yet you see an out of memory - that’s worrying. Please paste your output of the free command.
I notice that in both my installations (both have just 1G of RAM and 2G of swap) I have at some point followed that advice and set up vm.overcommit_memory=1 in /etc/sysctl.conf. (That’s not to say it would solve this current problem.)
We’ll be removing the ability to turn off Ember CLI assets very soon, so please make sure to figure out the problem with your setup soon. Otherwise, it will break again in a future update.
You’ll need a minimum of 1GB RAM + 2GB swap (per our standard installation script)
That is indeed concerning - please let us know what you see in the free output @itsbhanusharma
Hey @david
Here is free
root@discourse:~# free
              total        used        free      shared  buff/cache   available
Mem:        3932016     3747708       87928       12812       96380        9960
Swap:       2097148     1095852     1001296
Do you have anything else running on the server? The ‘used’ numbers there seem quite high for a standard Discourse install :thinking:
available 9960
That’s not much :scream:
How many unicorns are you running?
It is a multisite discourse installation. There are a few additional containers (e.g. mail receiver & an uptime monitor) but nothing out of ordinary.
UNICORN_WORKERS: 4
What does free look like after a reboot?
