프로필에서 '공개 프로필 숨기기' 체크박스를 해제해도 프로필이 열리지 않습니다
can not make my profile open even i uncheck the “Hide my public profile” checkbox in profile
Hmm… does logging out then back in help?
Also, if this is on Meta, I can see your public profile.
P.S. you may want to censor your email address; it’s visible in the screenshot.
After you mark the checkbox have you also saved it? Some profile pages have a main save changes after making them.
That is because of your trust level. By default, profiles of users with a low trust level are hidden to discourage spammers from creating accounts and adding spam links.
You can find out a little more in 3.4.0.beta3: Check for updates on What’s New page, filter by user in the review queue, threading in Chat DMs and group chats, and more
i mean unlogin user can not see it, if you open it in a guest browser, you will find it, not show if it is the default setting
yes, find it here
Are you concerned about your profile visibility on this site for any specific reason?
