I noticed on my forum and also on Meta that topics are bumped when the title is edited. For me this is quite confusing because the topic appears at the top of the topic list, so I expect something new, but it’s very difficult to spot the change because usually I am taken to the latest post while the edit happened on the first post.
I noticed you changed that edits on the last post no longer bump the topic. Is it possible that the fact that edits of the topic title now trigger a bump is a side effect of that change?
Thanks Moin, I see now…since I’m no longer checking if it’s the last post, I need to check if only topic OP stuff is changing and bypass the bump if so.
I have a fix here:
I was able to reproduce with category changes but not tag changes.
Hmm okay I think it’s valid for the title not to bump the topic, but I think the category + tag edit based bumps are complicated by these two settings:
These control whether a topic is bumped when editing the OP:
But, these settings also control whether an actual notification is sent when changing category/tags so it’s a bit complex to detangle. Will discuss this internally a bit and loop back.
Before you removed the bump on edits, title, category, and tag changes only bumped the topic when it had no replies. Otherwise, no bump happened because it wasn’t the last post. Do you plan to restore that, or do you want to block these bumps too?
I also wondered why a category edit on my test topic didn’t bump the topic now. I have the impression it’s because of the editing grace period. After waiting for 5 minutes, editing the category bumped the topic again.
I am still confused about what causes a bump now, apart from a reply. Understanding that could help me find solutions for how I notice edits where the user followed the Discourse instructions to edit their post instead of posting consecutive replies[1]. I think it might be a frustrating experience when the system tells you to edit your post instead of replying, you do that, and no one notices. I also asked for help on how edits on wikis can be tracked now.
Happy birthday
“No more than %{count} consecutive replies are allowed. Please edit your previous reply, or wait for someone to reply to you.” ↩︎
For my use, editing a topic to bump it to the top of the latest feed was a feature, not a bug. I relied on this behaviour to communicate to users that there had been a change in topics.
The last post being edited, causing the bump, is probably relied on by many to lift posts up the latest feed and bring items to people’s attention.
Communicating the change by replying to a post is not as efficient as once a user has read post 1, bumping with a reply will take them to the reply, if the edit is in post 1 (which it always is in my case), they won’t see it.
If there were a setting available to toggle this change, people could really tweak this to their liking, rather than flipping a long established feature on its head
I don’t always want to bump a topic edit, but sometimes I’d like to make a timely change more obvious. Auto-bump is an option, but not quite what I’d like:
It’s tempting to suggest a “Now” option on the auto-bump menu, but the auto-bump notice also indicates an automatic – not deliberate – bump, which is a different signal:
I’ve sometimes wished for a topic bump-on-edit option that could be enabled for roles or trust levels. I imagine buttons for “Save Edit” and “Save Edit and Bump”:
…and the resulting notice might say Topic edited by staff or similar.
