Migrer un forum XenForo vers Discourse
Hey guys so after trying for a week or so I decided to import the database on docker app which I hoped it will succeed without any issues. TBH I got some issues at first but it turned to be all easy to solve.
Now I would recommend doing this only once before you deploy your production site, after importing everything take a Discourse backup, wipe everything out and install new Discourse instance then restore the imported db.
Ok let’s begin:
  1. First lets backup your old database from your old server, sign in to your Discourse server then:
     ssh USER@XENFORO_SERVER_IP  # Use -p argument to specify custom port
     mysqldump -u XENFORO_DATABASE_USER -p XENFORO_DATABASE_NAME > xen_db.sql
     exit
  2. After installing Discourse start the app:
     ./launcher start app
  3. Now lets pull the database backup from xenforo server:
     scp USER@XENFORO_SERVER_IP:~/xen_db.sql /var/discourse/shared/standalone/xen_db.sql
    If you changed the ssh port use -P argument
     scp -P 2222 USER@XENFORO_SERVER_IP:~/xen_db.sql /var/discourse/shared/standalone/xen_db.sql
  4. Login to docker machine, install and start mysql:
     docker exec -it app bash
     sudo apt-get update
     sudo apt-get upgrade
    During the installation you will be asked to set a root password for mysql
     sudo apt-get install mysql-server mysql-client libmysqlclient-dev
     service mysql start
  5. Login to mysql and create new database:
     mysql -u root -p
    Enter your mysql root password then
     create database xenforo_db;
     exit;
  6. Import your xenforo database into the new one:
     mysql -u root -p xenforo_db < /shared/xen_db.sql
     # Enter your mysql root password and wait until it finish
  7. Include the gem in discourse Gemfile:
     echo "gem 'mysql2'" >>Gemfile
  8. Run bundle install:
     bundle install --no-deployment
  9. Edit the importer script and change the following:
    vi /var/www/discourse/script/import_scripts/xenforo.rb
    XENFORO_DB = "xenforo_db"
    @client = Mysql2::Client.new(
      host: "localhost",
      username: "root",
      password: "Your mysql root password",
      database: XENFORO_DB
  10. You are set to go now, run the importer:
    RAILS_ENV=production bundle exec ruby script/import_scripts/xenforo.rb
  11. If you get the error 'Peer authentication failed for user "discourse"':
  12. Edit the file /etc/postgresql/9.5/main/pg_hba.conf
  13. change all ‘peer’ to ‘trust’ and save the file
  14. restart postgres server: service postgresql restart
Run the importer again and this time it should work without any problem, be patient this might take a while based on your database size.
Hope this helps someone. :slight_smile:
24 « J'aime »
What are the list of XenForo Data covered on this import?
I hope to import this list:
XenForo Page Nodes
  • Pages
XenForo
  • Profile Fields
  • Member Groups
  • Members
  • Status Updates / Profile Comments
  • Status Comments
  • Private Messages
  • Private Message Replies
  • Attachments
  • Member Ranks
XenForo Forums
  • Forums
  • Topics
  • Posts
  • Attachments
1 « J'aime »
Got this error:
# bundle install --no-deployment
Don't run Bundler as root. Bundler can ask for sudo if it is needed, and installing your bundle as root will break this application for all non-root users on this machine.
Your Gemfile has no gem server sources. If you need gems that are not already on your machine, add a line like this to your Gemfile:
source 'https://rubygems.org'
Could not find gem 'mysql2' in any of the gem sources listed in your Gemfile.
1 « J'aime »
Different Error now.
root@discourse-app:/var/www/discourse# RAILS_ENV=production bundle exec ruby script/import_scripts/xenforo.rb
No connection to db, unable to retrieve site settings! (normal when running db:create)
Traceback (most recent call last):
	31: from script/import_scripts/xenforo.rb:3:in `<main>'
	30: from script/import_scripts/xenforo.rb:3:in `require'
	29: from /var/www/discourse/script/import_scripts/base.rb:20:in `<top (required)>'
	28: from /var/www/discourse/script/import_scripts/base.rb:544:in `<class:Base>'
	27: from /var/www/discourse/lib/discourse.rb:411:in `system_user'
	26: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/core.rb:196:in `find_by'
	25: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/core.rb:196:in `all?'
	24: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/core.rb:196:in `each'
	23: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/core.rb:196:in `block in find_by'
	22: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/model_schema.rb:336:in `columns_hash'
	21: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/model_schema.rb:456:in `load_schema'
	20: from /usr/local/lib/ruby/2.5.0/monitor.rb:226:in `mon_synchronize'
	19: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/model_schema.rb:459:in `block in load_schema'
	18: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/attribute_decorators.rb:51:in `load_schema!'
	17: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/attributes.rb:234:in `load_schema!'
	16: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/model_schema.rb:466:in `load_schema!'
	15: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_handling.rb:90:in `connection'
	14: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_handling.rb:118:in `retrieve_connection'
	13: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:1008:in `retrieve_connection'
	12: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:380:in `connection'
	11: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:521:in `checkout'
	10: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:793:in `acquire_connection'
	 9: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:832:in `try_to_checkout_new_connection'
	 8: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:853:in `checkout_new_connection'
	 7: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/abstract/connection_pool.rb:809:in `new_connection'
	 6: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:40:in `postgresql_connection'
	 5: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:40:in `new'
	 4: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:215:in `initialize'
	 3: from /usr/local/lib/ruby/gems/2.5.0/gems/activerecord-5.2.0/lib/active_record/connection_adapters/postgresql_adapter.rb:684:in `connect'
	 2: from /usr/local/lib/ruby/gems/2.5.0/gems/pg-1.0.0/lib/pg.rb:56:in `connect'
	 1: from /usr/local/lib/ruby/gems/2.5.0/gems/pg-1.0.0/lib/pg.rb:56:in `new'
/usr/local/lib/ruby/gems/2.5.0/gems/pg-1.0.0/lib/pg.rb:56:in `initialize': FATAL:  Peer authentication failed for user "discourse" (PG::ConnectionBad)
1 « J'aime »
Yay no idea how long this will take :smiley:
3 « J'aime »
This is correct right?
1 « J'aime »
Guide needs an update I think.
Before running this, directory must be within /var/www/discourse/.
cd /var/www/discourse/
4 « J'aime »
3 messages ont été divisées dans un nouveau sujet : XenForo import script imported banned users and soft-deleted topics and posts
8 messages ont été déplacés vers un nouveau sujet : Aide pour la migration de XenForo
14 messages ont été déplacées vers un nouveau sujet : Problèmes lors de l’importation de pièces jointes depuis XenForo
5 messages ont été déplacées vers un nouveau sujet : Difficultés à passer de XenForo à Discourse
Un message a été fusionné dans un sujet existant : Difficultés à passer de XenForo à Discourse
Je vais juste vous demander pourquoi vous êtes passés de XenForo à Discourse ? J’ai lancé un forum il y a une semaine et j’ai vu des sites fonctionnant sous XenForo ; je suis impressionné par leurs plugins, notamment le système de points. Je voulais simplement connaître les inconvénients ou les raisons de ce changement. Merci.
Je viens de terminer une migration de Xenforo vers Discourse d’un forum d’un million de messages sur un droplet Digital Ocean. Voici ce qui a fonctionné pour moi, commande par commande (très similaire à ce que je viens de faire sur un autre forum vBulletin).
Je recommande un minimum de 4 vCPU/8 Go pour l’importation.
Merci à tous ceux qui ont participé à ce fil pour m’avoir aidé à réaliser ces migrations ; cela a été quelques jours bien remplis à lire et relire…
1 - Installer le droplet Discourse 1-clic de Digital Ocean
2 - Terminer l’installation de Discourse via SSH en suivant les invites
Ouvrir la console SSH
root
(votre_mot_de_passe_root)
(entrer)
(votredomaine).com
etc
3 - Se connecter en SFTP
sftp root@XXX.XXX.XX.XX
y (si une confirmation est demandée)
yes
put db.sql /var/discourse/shared/standalone/db.sql
4 - Se connecter au site web pour configurer le compte administrateur
5 - Se connecter en SSH - Démarrer le processus
ssh root@XXX.XXX.XX.XX
cd /var/discourse
sudo apt-get update
y
6 - Installer MariaDB (remplacement de mysql)
apt-get update && apt-get install mariadb-server-10.3 libmariadbd-dev
y
7 - Configuration de la base de données MySQL
service mysql start
mysql -u root -p
mot_de_passe
create database import_db;
exit;
8 - Importation du dump → Transfert vers la base de données MySQL**
mysql -u root -p import_db < /shared/db.sql
mot_de_passe
9 - Fichier GEM
echo "gem 'mysql2', require: false" >> /var/www/discourse/Gemfile
echo "gem 'php_serialize', require: false" >> /var/www/discourse/Gemfile
su discourse -c 'bundle install --no-deployment --without test --without development --path vendor/bundle'
(ignorer le résultat en rouge)
10 - Configurer le script d’installation
---Apporter les modifications nécessaires au fichier texte pour le nom de la base de données/mot de passe, le préfixe, etc---
(esc)
:wq
11 - Configuration de Bundle
bundle config set path 'vendor/bundle'
bundle config set without 'development:test'
bundle config unset deployment
su discourse -c 'bundle install'
12 - Configuration MySQL (il est peut-être possible de le faire avec l’étape précédente)
mysql --version
sudo mysql -u root -p
mot_de_passe
ALTER USER 'root'@'localhost' IDENTIFIED BY 'mot_de_passe';
FLUSH PRIVILEGES;
exit
13 - Script d’installation
su discourse -c 'bundle exec ruby script/import_scripts/xenforo.rb'
4 « J'aime »
Je suis en train d’essayer de finaliser cette migration, mais il semble qu’une erreur se produise avec les pièces jointes.
Chargement des groupes existants...
Chargement des utilisateurs existants...
Chargement des catégories existantes...
Chargement des publications existantes...
Chargement des sujets existants...
création des utilisateurs
407 utilisateurs déjà importés ignorés
importation des catégories...
       12 / 12 (100.0%)  [344731 éléments/min]
création des sujets et des publications
        2 / 4554 (  0.0%)  [17724 éléments/min]  Traceback (appel de la pile le plus récent en dernier):
        18: from script/import_scripts/xenforo.rb:396:in `<main>'
        17: from /var/www/discourse/script/import_scripts/base.rb:47:in `perform'
        16: from script/import_scripts/xenforo.rb:32:in `execute'
        15: from script/import_scripts/xenforo.rb:174:in `import_posts'
        14: from /var/www/discourse/script/import_scripts/base.rb:866:in `batches'
        13: from /var/www/discourse/script/import_scripts/base.rb:866:in `loop'
        12: from /var/www/discourse/script/import_scripts/base.rb:867:in `block in batches'
        11: from script/import_scripts/xenforo.rb:180:in `block in import_posts'
        10: from /var/www/discourse/script/import_scripts/base.rb:508:in `create_posts'
         9: from /var/www/discourse/script/import_scripts/base.rb:508:in `each'
         8: from /var/www/discourse/script/import_scripts/base.rb:509:in `block in create_posts'
         7: from script/import_scripts/xenforo.rb:186:in `block (2 levels) in import_posts'
         6: from script/import_scripts/xenforo.rb:315:in `process_xenforo_post'
         5: from script/import_scripts/xenforo.rb:324:in `process_xf_attachments'
         4: from /usr/local/lib/ruby/2.7.0/set.rb:328:in `each'
         3: from /usr/local/lib/ruby/2.7.0/set.rb:328:in `each_key'
         2: from script/import_scripts/xenforo.rb:326:in `block in process_xf_attachments'
         1: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/core_ext/string/filters.rb:22:in `squish!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.0.3.3/lib/active_support/core_ext/string/filters.rb:22:in `gsub!': impossible de modifier une chaîne figée : "\\t\\tSELECT a.attachment_id, a.data_id, d.fil\n\\t\\tFROM xf_attachment AS a\\n\\t\\tINNER JOIN xf_attachment_data d ON a.data_id = d.data_id\\n\\t\\tWHERE attachment_id = 13\\n" (FrozenError)
Avez-vous des idées sur ce qui pourrait se passer ici ? Qu'est-ce que "FrozenError" ?
Il semble que j’aie dû modifier le fichier xenforo.rb et remplacer
# frozen_string_literal: true
par
# frozen_string_literal: false
2 « J'aime »
Merci d’avoir rédigé ce guide !
L’importateur importe-t-il également les avatars et les pièces jointes ? Dois-je simplement les copier dans le dossier /tmp/attachments ?
À première vue, l’importateur semble ne gérer que les uploads vers les articles. Le support des avatars devrait être ajouté.
2 « J'aime »
Je peux confirmer. Seuls les fichiers uploadés sont importés. Les avatars ne sont pas inclus. J’ai terminé une migration XenForo la semaine dernière.
3 « J'aime »
Taille du tableau ?
Publications/sujets/membres.
Félicitations :slight_smile:
2 « J'aime »
