500 error mit Automation Plugin
Hallo,
seit dem letzten Update erhalten wir mit dem Automatisierungs-Plugin einen “500 Internal Server Error”.
plugins/automation/lib/discourse_automation/scripts/auto_responder.rb:60:in `block (2 levels) in <main>'
plugins/automation/app/models/discourse_automation/automation.rb:141:in `trigger!'
plugins/automation/lib/discourse_automation/event_handlers.rb:64:in `block in handle_post_created_edited'
activerecord (7.0.8.1) lib/active_record/relation/batches.rb:71:in `each'
activerecord (7.0.8.1) lib/active_record/relation/batches.rb:71:in `block in find_each'
activerecord (7.0.8.1) lib/active_record/relation/batches.rb:138:in `block in find_in_batches'
activerecord (7.0.8.1) lib/active_record/relation/batches.rb:245:in `block in in_batches'
activerecord (7.0.8.1) lib/active_record/relation/batches.rb:229:in `loop'
activerecord (7.0.8.1) lib/active_record/relation/batches.rb:229:in `in_batches'
activerecord (7.0.8.1) lib/active_record/relation/batches.rb:137:in `find_in_batches'
activerecord (7.0.8.1) lib/active_record/relation/batches.rb:70:in `find_each'
plugins/automation/lib/discourse_automation/event_handlers.rb:14:in `handle_post_created_edited'
plugins/automation/plugin.rb:186:in `block (2 levels) in activate!'
lib/plugin/instance.rb:554:in `block in on'
lib/discourse_event.rb:12:in `block in trigger'
/usr/local/lib/ruby/3.2.0/set.rb:511:in `each_key'
/usr/local/lib/ruby/3.2.0/set.rb:511:in `each'
lib/discourse_event.rb:12:in `trigger'
lib/post_creator.rb:258:in `trigger_after_events'
lib/post_creator.rb:220:in `create'
lib/new_post_manager.rb:318:in `perform_create_post'
lib/new_post_manager.rb:252:in `perform'
app/controllers/posts_controller.rb:201:in `create'
actionpack (7.0.8.1) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.0.8.1) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack (7.0.8.1) lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:118:in `block in run_callbacks'
app/controllers/application_controller.rb:423:in `block in with_resolved_locale'
i18n (1.14.4) lib/i18n.rb:322:in `with_locale'
app/controllers/application_controller.rb:423:in `with_resolved_locale'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack (7.0.8.1) lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/rescue.rb:23:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport (7.0.8.1) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.0.8.1) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (7.0.8.1) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.0.8.1) lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.0.8.1) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (7.0.8.1) lib/abstract_controller/base.rb:151:in `process'
actionview (7.0.8.1) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionpack (7.0.8.1) lib/action_controller/metal.rb:188:in `dispatch'
actionpack (7.0.8.1) lib/action_controller/metal.rb:251:in `dispatch'
actionpack (7.0.8.1) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.0.8.1) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.0.8.1) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (7.0.8.1) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (7.0.8.1) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.0.8.1) lib/action_dispatch/routing/route_set.rb:852:in `call'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack (2.2.9) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.9) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.9) lib/rack/head.rb:12:in `call'
actionpack (7.0.8.1) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
lib/middleware/anonymous_cache.rb:393:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
rack (2.2.9) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.9) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack (7.0.8.1) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/show_exceptions.rb:29:in `call'
logster (2.19.1) lib/logster/middleware/reporter.rb:40:in `call'
railties (7.0.8.1) lib/rails/rack/logger.rb:40:in `call_app'
railties (7.0.8.1) lib/rails/rack/logger.rb:27:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/request_id.rb:26:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
rack (2.2.9) lib/rack/method_override.rb:24:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.9) lib/rack/sendfile.rb:110:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:191:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
lib/middleware/request_tracker.rb:274:in `call'
railties (7.0.8.1) lib/rails/engine.rb:530:in `call'
railties (7.0.8.1) lib/rails/railtie.rb:226:in `public_send'
railties (7.0.8.1) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.9) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.9) lib/rack/urlmap.rb:58:in `each'
rack (2.2.9) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
Wir verwenden die neueste Version von Discourse und dem Automatisierungs-Plugin. Haben Sie eine Idee, wie dies behoben werden kann? Vielen Dank für Ihre Hilfe!
Ich weiß nicht, ob es damit zusammenhängt, aber
Sie könnten also versuchen, das Plugin aus Ihrer app.yml zu entfernen.
Hmm, wir haben das Repository bereits geleert, daher hat dies nichts mit dem alten Plugin zu tun.
Wir haben kürzlich ein wenig mit diesem Trigger gespielt, vielleicht hat @Osama einige Ideen.
Gibt es weitere Informationen in Ihren Protokollen @Festinger, was ist die Nachricht?
Können Sie eine neue Automatisierungsregel von Grund auf für dieselbe Aktion erstellen, funktioniert das als Problemumgehung?
Können Sie bitte die Fehlermeldung mitteilen? Sie sollte direkt vor dem Stacktrace angezeigt werden, den Sie geteilt haben.
Vielen Dank für Ihr Feedback.
Bei der Überprüfung der Automatisierungsregeln habe ich festgestellt, dass sich der einer Regel zugewiesene Benutzername geändert hat und wir vergessen haben, den Benutzernamen zu aktualisieren.
Da wir nun den richtigen Benutzernamen zugewiesen haben, sind die Fehler behoben und die Automatisierungsregeln funktionieren wieder.
