Polls disabled caused 500 error
I just performed a update to the latest version of discourse (test-passed). After that update, I get an error message when accessing any topic in the forum. Something that translates to: Sorry, we couldn’t load the topic – probably due to a connection error. Please try again.
The production logs keeps showing
Completed 500 Internal Server Error in 439ms (ActiveRecord: 425.3ms)
LocalJumpError (unexpected return)
/var/www/discourse/lib/plugin/instance.rb:188:in `block (2 levels) in topic_view_post_custom_fields_whitelister'
for almost all requests.
Any help would be appreciated.
Rebuilding the app did not help.
What plugins do you have installed?
docker_manager
discourse-solved
discourse-cakeday
Do you have any other plugins installed, but disabled?
That was the list from app.yml. I don’t know any other place where plugins could be specified.
I have just created a fix, it will take a few minutes to reach tests-passed
However, none of those three plugins make use of this particular part of the code, so I am unsure why the error is occurring for you.
@some-user it’s now in tests-passed, so please try updating again and see if that fixes the issue.
Thanks for the notification :slight_smile: Update is installed, problem solved. Amazingly quick support. :star_struck: Thank you very much!
If you want to look into that and I can do anything to support, let me know. But as the patient is alive again…
Good to hear :slight_smile:
I have one idea - do you have the built-in “polls” plugin disabled? (check the poll enabled site setting). That would explain it.
Yes, it is was. :relieved:
Mystery solved! :male_detective:
(now that the bug is fixed, it is perfectly safe to leave it disabled if you want)
