I get a 500 Error while trying to post a new Topic. I am the Admin and have posted and am able to post multiple other topics. But, only few set of topics are throwing me an error.
Title:
Why should I learn computer programming even though I am a commerce student? How can computer programming help me?
Post:
First of all in couple of years everything will be programmable so it will be useful thing to know. But you might not care about that since you will be only consumer - and that is fine to be clear.Even though you do not know every law in the book like professional lawyer you still know few of your basic rights so why not learn some basics of computer programming?As a commerce student I expect that you will be working with a bunch of numbers and if you have repetitive tasks having them automated can save you a bunch of time.Last but not least you should never turn down opportunity to learn s Continue ReadingFirst of all in couple of years everything will be programmable so it will be useful thing to know. But you might not care about that since you will be only consumer - and that is fine to be clear.Even though you do not know every law in the book like professional lawyer you still know few of your basic rights so why not learn some basics of computer programming?As a commerce student I expect that you will be working with a bunch of numbers and if you have repetitive tasks having them automated can save you a bunch of time.Last but not least you should never turn down opportunity to learn something new: be it playing instrument, new language or just good old programming.
Could someone help me understand what could possible go wrong here
IAmGav
(Gavin Perch)
August 4, 2020, 8:14am
It could be you topic character limit. You might be exceeding the limit
Hi @IAmGav ,
I have kept the topic character limit to the maximum.
I have increase the max post length to 150000.
Max Topic Title Length to 255.
Title max word length to 2000000000
Any other possible reason.
The Number of 500 Errors have been increasing considerably. Not able to identify the exact reason. This is severely affecting my forum. Could you someone please help me here.
IAmGav
(Gavin Perch)
August 4, 2020, 4:11pm
5
I went ahead and took your article and posted it on one of my discourse server without even touching any limits.
It posted fine.
You might want to look at your server errors.
This is not a discourse related error
Thank You Gavin.
Not sure why all of a sudden this has started to happen
Falco
(Falco)
August 4, 2020, 5:37pm
7
Visit the /logs page on your forum and check for errors.
/logs page does not exist in the domain. (mpl.co/logs )
Could you please help me understand how to access.
Falco
(Falco)
August 4, 2020, 6:11pm
9
You must be logged in as the forum admin.
I am a forum Admin. Do we have to configure it?
Is it true that this might be caused due to similar body content, as mentioned here,
When posting, I sometimes get a “500” error and then the message “Body is too similar to what you recently posted” when I retry. Nothing is successfully posted in such cases.
Reading time: 1 min 🕑
Likes: 1 ❤
If yes, how to disable this feature. I’m comfortable having a Check for duplicate titles. But, I don’t want Discourse to throw and error for similar body
sam
(Sam Saffron)
August 4, 2020, 11:57pm
13
We can not really help much without seeing the /logs visit YOURSITENAME.COM/logs after triggering the issue, copy the error you get and paste it here.
Error Message:
ActiveRecord::ValueTooLong (PG::StringDataRightTruncation: ERROR: value too long for type character varying(1000) ) lib/post_creator.rb:496:in `update_topic_stats' lib/post_creator.rb:199:in `block i
Error Info:
lib/post_creator.rb:199:in `block in create'
lib/post_creator.rb:375:in `block in transaction'
lib/post_creator.rb:374:in `transaction'
lib/post_creator.rb:191:in `create'
lib/new_post_manager.rb:271:in `perform_create_post'
lib/new_post_manager.rb:209:in `perform'
app/controllers/posts_controller.rb:173:in `block in create'
lib/distributed_memoizer.rb:30:in `memoize'
app/controllers/posts_controller.rb:172:in `create'
app/controllers/application_controller.rb:340:in `block in with_resolved_locale'
app/controllers/application_controller.rb:340:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:68:in `call'
lib/middleware/anonymous_cache.rb:328:in `call'
config/initializers/100-quiet_logger.rb:19:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:22:in `call'
lib/middleware/request_tracker.rb:176:in `call'
Error Back Trace:
rack-mini-profiler (2.0.3) lib/patches/db/pg.rb:69:in `exec_params'
activerecord (6.0.3.2) lib/active_record/connection_adapters/postgresql_adapter.rb:675:in `block (2 levels) in exec_no_cache'
activesupport (6.0.3.2) lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
activesupport (6.0.3.2) lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
activesupport (6.0.3.2) lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
activerecord (6.0.3.2) lib/active_record/connection_adapters/postgresql_adapter.rb:674:in `block in exec_no_cache'
activerecord (6.0.3.2) lib/active_record/connection_adapters/abstract_adapter.rb:722:in `block (2 levels) in log'
activesupport (6.0.3.2) lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
activesupport (6.0.3.2) lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
activesupport (6.0.3.2) lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
activesupport (6.0.3.2) lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
activesupport (6.0.3.2) lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
activerecord (6.0.3.2) lib/active_record/connection_adapters/abstract_adapter.rb:721:in `block in log'
activesupport (6.0.3.2) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activerecord (6.0.3.2) lib/active_record/connection_adapters/abstract_adapter.rb:712:in `log'
activerecord (6.0.3.2) lib/active_record/connection_adapters/postgresql_adapter.rb:673:in `exec_no_cache'
activerecord (6.0.3.2) lib/active_record/connection_adapters/postgresql_adapter.rb:654:in `execute_and_clear'
activerecord (6.0.3.2) lib/active_record/connection_adapters/postgresql/database_statements.rb:111:in `exec_delete'
activerecord (6.0.3.2) lib/active_record/connection_adapters/abstract/database_statements.rb:174:in `update'
activerecord (6.0.3.2) lib/active_record/connection_adapters/abstract/query_cache.rb:22:in `update'
activerecord (6.0.3.2) lib/active_record/persistence.rb:385:in `_update_record'
activerecord (6.0.3.2) lib/active_record/persistence.rb:681:in `update_columns'
activerecord (6.0.3.2) lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `block in transaction'
activerecord (6.0.3.2) lib/active_record/connection_adapters/abstract/transaction.rb:280:in `block in within_new_transaction'
activerecord (6.0.3.2) lib/active_record/connection_adapters/abstract/transaction.rb:278:in `within_new_transaction'
activerecord (6.0.3.2) lib/active_record/connection_adapters/abstract/database_statements.rb:280:in `transaction'
activerecord (6.0.3.2) lib/active_record/transactions.rb:212:in `transaction'
actionpack (6.0.3.2) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (6.0.3.2) lib/abstract_controller/base.rb:195:in `process_action'
actionpack (6.0.3.2) lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack (6.0.3.2) lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport (6.0.3.2) lib/active_support/callbacks.rb:112:in `block in run_callbacks'
i18n (1.8.3) lib/i18n.rb:313:in `with_locale'
activesupport (6.0.3.2) lib/active_support/callbacks.rb:121:in `block in run_callbacks'
activesupport (6.0.3.2) lib/active_support/callbacks.rb:139:in `run_callbacks'
actionpack (6.0.3.2) lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack (6.0.3.2) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (6.0.3.2) lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
activesupport (6.0.3.2) lib/active_support/notifications.rb:180:in `block in instrument'
activesupport (6.0.3.2) lib/active_support/notifications.rb:180:in `instrument'
actionpack (6.0.3.2) lib/action_controller/metal/instrumentation.rb:32:in `process_action'
actionpack (6.0.3.2) lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
activerecord (6.0.3.2) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (6.0.3.2) lib/abstract_controller/base.rb:136:in `process'
actionview (6.0.3.2) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (2.0.3) lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method'
actionpack (6.0.3.2) lib/action_controller/metal.rb:190:in `dispatch'
actionpack (6.0.3.2) lib/action_controller/metal.rb:254:in `dispatch'
actionpack (6.0.3.2) lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
actionpack (6.0.3.2) lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack (6.0.3.2) lib/action_dispatch/journey/router.rb:49:in `block in serve'
actionpack (6.0.3.2) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (6.0.3.2) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (6.0.3.2) lib/action_dispatch/routing/route_set.rb:834:in `call'
rack (2.2.3) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.3) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.3) lib/rack/head.rb:12:in `call'
rack (2.2.3) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.3) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/cookies.rb:648:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (6.0.3.2) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (6.0.3.2) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster (2.9.1) lib/logster/middleware/reporter.rb:43:in `call'
railties (6.0.3.2) lib/rails/rack/logger.rb:37:in `call_app'
railties (6.0.3.2) lib/rails/rack/logger.rb:28:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/request_id.rb:27:in `call'
rack (2.2.3) lib/rack/method_override.rb:24:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.3) lib/rack/sendfile.rb:110:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/host_authorization.rb:76:in `call'
rack-mini-profiler (2.0.3) lib/mini_profiler/profiler.rb:200:in `call'
message_bus (3.3.1) lib/message_bus/rack/middleware.rb:61:in `call'
railties (6.0.3.2) lib/rails/engine.rb:527:in `call'
railties (6.0.3.2) lib/rails/railtie.rb:190:in `public_send'
railties (6.0.3.2) lib/rails/railtie.rb:190:in `method_missing'
rack (2.2.3) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.
Error Env:
hostname
discourse-app
process_id
21623
application_version
8a9e4504fea9edd693ceecf314308cd08e99f0ca
HTTP_HOST
mpl.co
REQUEST_URI
/posts.json
REQUEST_METHOD
POST
HTTP_USER_AGENT
python-requests/2.22.0
HTTP_ACCEPT
application/json
HTTP_X_FORWARDED_FOR
183.82.159.193
HTTP_X_REAL_IP
183.82.159.193
username
Nideesh
time
11:41 am
Please suggest next steps.
sam
(Sam Saffron)
August 5, 2020, 6:21am
15
This is happening due to excerpts.
Please change the Site Setting topic_excerpt_maxlength to 999.
https://github.com/discourse/discourse/commit/ee10002e207344106e90240fb46811e92aef45a8
Thanks @sam …Issue got resolved
sam
(Sam Saffron)
Closed
August 6, 2020, 8:00am
17
This topic was automatically closed after 25 hours. New replies are no longer allowed.
