Internal Error 500 when creating a topic
I’m on beta 10. When a specific user tries to create a topic in any category - it gives a Internal Error 500. It happens just for this user, and in any category they try to post. Very strange.
Below is the backtrace. Any clues?
/var/www/discourse/app/models/topic_user.rb:102:in `>='
/var/www/discourse/app/models/topic_user.rb:102:in `block in change'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:199:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/transactions.rb:208:in `transaction'
/var/www/discourse/app/models/topic_user.rb:85:in `change'
/var/www/discourse/app/models/topic_notifier.rb:40:in `change_level'
/var/www/discourse/app/models/topic_notifier.rb:18:in `watch_topic!'
/var/www/discourse/lib/topic_creator.rb:64:in `watch_topic'
/var/www/discourse/lib/topic_creator.rb:42:in `create'
/var/www/discourse/lib/post_creator.rb:266:in `create_topic'
/var/www/discourse/lib/post_creator.rb:123:in `block in create'
/var/www/discourse/lib/post_creator.rb:215:in `call'
/var/www/discourse/lib/post_creator.rb:215:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:201:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:209:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:201:in `transaction'
/var/www/discourse/lib/post_creator.rb:213:in `transaction'
/var/www/discourse/lib/post_creator.rb:121:in `create'
/var/www/discourse/lib/new_post_manager.rb:150:in `perform_create_post'
/var/www/discourse/lib/new_post_manager.rb:123:in `perform'
/var/www/discourse/app/controllers/posts_controller.rb:114:in `create'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/abstract_controller/base.rb:189:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/rendering.rb:10:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/callbacks.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/callbacks.rb:552:in `block (2 levels) in compile'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/callbacks.rb:502:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/callbacks.rb:86:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/notifications.rb:159:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/notifications.rb:159:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/abstract_controller/base.rb:136:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionview-4.1.10/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.6/lib/mini_profiler/profiling_methods.rb:77:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_controller/metal.rb:232:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/routing/route_set.rb:82:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/routing/route_set.rb:82:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/routing/route_set.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/journey/router.rb:73:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/journey/router.rb:59:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/journey/router.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/routing/route_set.rb:692:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:186:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:164:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/builder.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/conditionalget.rb:35:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/head.rb:11:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:124:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/flash.rb:254:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/message_bus-1.0.16/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/cookies.rb:562:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/connection_pool.rb:621:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/callbacks.rb:82:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/remote_ip.rb:76:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/logster-1.0.0.3.pre/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.10/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.10/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/quiet_logger.rb:10:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/silence_logger.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.1.10/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/methodoverride.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/runtime.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/sendfile.rb:112:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.6/lib/mini_profiler/profiler.rb:170:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:72:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.10/lib/rails/engine.rb:514:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.10/lib/rails/application.rb:144:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.10/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.1.10/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/builder.rb:138:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/urlmap.rb:65:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.5.5/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/lib/unicorn/http_server.rb:576:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/lib/middleware/unicorn_oobgc.rb:95:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/lib/unicorn/http_server.rb:670:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/lib/unicorn/http_server.rb:525:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/lib/unicorn/http_server.rb:140:in `start'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.8.3/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `<main>'
Info tab:
ArgumentError (comparison of String with 0 failed)
Yeah I know what that is, provided you are on latest go to site settings and jiggle your default user watching settings
Latest beta or latest tests-passed? What do I jiggle?
what changes have you made in /admin/site_settings/category/user_preferences
email digest > 3 days
new topic duration > haven’t viewed them
auto track > immediately
external links in new tabs > TRUE
Jiggle both of those, change them to something, save, then change back.
Ok will do. Again, this is only happening to one user, which is odd.
Update: Did as you said, impersonated the user, tried to post. Same error.
What is “Automatically track topics I enter” setting on said users profile? Can you change it around and see if that fixes?
That fixed it. Thank you.
Oddly though it was also set as “immediately” which ever other user also has (as default) with no problems posting.
odd, maybe we had a version that was sending that as text at some point, I will add a to_i which should fix it for junk data and close this.
