إعداد Let's Encrypt مع عدة نطاقات / تحويلات
NOTE: @pfaffman says: This page needs to be cleaned up. There is now a new ENV setting that will let you add more hostnames. In your app.yml under your DISCOURSE_HOSTNAME line (it can go many places but that one makes sense), add
 DISCOURSE_HOSTNAME_ALIASES: domain.com,other.domain.com
and early reports suggest that you’ll get valid certs for those domains and that accessing https://domain.com will properly redirect you to your DISCOURSE_HOSTNAME without a certificate error.
If you do that and it works for you, you might add another “me too!” post to the bottom. If you feel comfortable, you could also edit this first post with the instructions that you think would be most helpful.
This is to address the problem where you get certificate errors with any redirects or CNAME DNS entries which point to your actual installed Discourse (sub)domain.
If you do not have https configured already (you do if you have done a standard install recently) see Setting up Let’s Encrypt as your first step.
Legacy Method
The method below no longer reliably works as of August 2025
There are three patterns that need to be replaced. Enter your (sub)domain (and any additional subdomains preceded by -d ) and then add the following to your app.yml hooks section (towards the end of the file):
2025-04-23 @pfaffman changed the code because there’s a 3rd place it needs to be changed
  after_ssl:
    - replace:
        filename: /etc/runit/1.d/letsencrypt
        to: "-d =domain1= -d =domain2= "
        global: true
This will allow you to have HTTPS configured for a second domain that will redirect to the correct one without certificate issues.
If you need to add multiple extra domains, you can enter something like this in the domain2 field: www.bananas.com -d forum.bananas.com
For example, if you want people who visit https://forum.example.com to be redirected to your forum at https://community.example.com without a certificate error, this is all you need.
49 إعجابًا
Discourse + Let's Encrypt w/ multiple hostnames
Problem in installing Let's Encrypt SSL for www and non-www
Making 'www' work with Discourse
LetsEncrypt working without www, not with www
Full site CDN acceleration for Discourse
Two domains, conditional redirect
How to setup 301 redirect -non-www to www
Best way to add a 301 redirect
Setup discourse for the main site (www.example.com) not on a subdomain
How to create 301 redirect to a new domain
I can't access after installing
Setting up Discourse
Migrating site from Personal vmware server to VPS
New install fails on Ubuntu 20.04.3 LTS
Discourse Setup Error
Www.example.com OK, but example.com NOT
About force www to non www
Why is the Apple Touch Icon loaded via HTTP instead of HTTPS?
DNS Settings for Digital Ocean Droplet - Root Domain?
SSL working on root, but not on www
Facebook login was flagged as non compliant by Facebook after change to Let's Encrypt certificate system
After activating HTTPS Discourse doesn´t work
Letsencrypt issued on every build?
DO Storage and uploaded backups not showing
Non www to www without certificate error
How to add ssl to non-www domain?
Adding www. to Domain
Discourse droplet unreachable on 80,443 ports after installation on Ubuntu 20.04
Installation without subdomain not working
Forum went down, then certificate renew error regarding firewall configuration?
Discourse Failing to Work
DNS settings for www
LetsEncrypt certificate not renewing
How to redirect http to https on digital ocean droplet?
Forwarding from https:// to https://www
Workaround for the 1 week Let's Encrypt limit
Migrate discourse from main domain --> subdomain
Let's Encrypt and multisite (on 2 containers)
Migrate a XenForo forum to Discourse
How can I update the nginx config directly in discourse/docker ..?
Let's Encrypt with sub-subdomain?
Problems building a new server
Multiple hostnames for a single site for cut-over phase
Help with URLs not working on Chrome
Issue after Rebuilding Discourse on Digital Ocean Droplet
Error on attempting to remap links
Unable to reinstall Discourse
Can't load site in Safari
Lets Encrypt Certificate - Issuing Problem
Www to non www with https
Discourse setup completed successfully but not working due to SSL error
SSL on new host
Install fails on fresh Debian 12 installation
Setup Multisite Configuration with Let's Encrypt and no Reverse Proxy
SSL is not valid for www.domain.com
Trying to set up Discourse on my website
Setup Let’s Encrypt + non-www > www
Changed email service, now the forum won't resolve via IP address nor URL
Bootstrap error during Discourse install: ENOENT - /etc/runit/1.d/letsencrypt
Various multisite installation questions
Redirection from https://www.mydoimain.com/ doesn't work
SSL cert not working on main Discourse site
Change server to a two-container setup
Infinite 301 redirect with reverse proxy setup
[Paid] Discourse configuration changes
New installer works well, but one hostname gave me fits
Redirect old forum URLs to new Discourse URLs using permalinks
Discourse not accessible - SSL Issue
Correct DNS records to set when Discourse is hosted on WWW subdomain?
Invalid certificate name when using www
Need help with dual container. Issue with LetsEncrypt for a few days now
PEM_read_bio_X509_AUX() failed (SSL: error:0909006C:PEM routines:get_name:no start line:Expecting: TRUSTED CERTIFICATE)
Rebuild appears to work, but site is not loading properly
Issue with app.yml file update
New install on ionos ubuntu 22.04 vps keeps failing
Connection Timeout/Security Issue
Let's Encrypt Limit (again)
Port issue - Please help
Starting a second Discourse forum on the same VPS
Sysadmins Index
Set Up Let's Encrypt with Second Domain for Existing Discourse Install
New domain new server and 301 redirect
Able to receive e-mail in mail-receiver but NOT in Discourse?
شكرًا، هل يعمل هذا على إعادة توجيه “www.example.com” إلى “comunnity.example.com”؟
أو كيف يمكنني القيام بذلك؟
لدي مشاكل مع نطاقي www.example.com، لقد قمت بتكوين نظام أسماء النطاقات (DNS) لإعادة التوجيه إلى comunnity.example.com ولكنه لا يعمل على فايرفوكس أو كروم.
إعجابَين (2)
هناك أداة فحص إعادة التوجيه للتحقق من عمليات إعادة التوجيه الخاصة بك.
6 إعجابات
أواجه صعوبة في هذا الأمر بعض الشيء. حسناً، كثيراً في الواقع.
قررت أن أجرب إضافة شبكة توصيل محتوى (CDN) إلى أحد مواقعي.
بعد قراءة الوثائق، أدركت أنه من الأفضل لموقعي الانتقال إلى نطاق فرعي من نطاقه الأصلي الحالي لتلبية المعايير التي أوصت بها Fastly (والنصيحة العامة للقيام بذلك).
لذا فكرت: “مهلاً، سيكون هذا سهلاً، لقد فعلت ذلك من قبل…” هل حقاً؟ :sweat_smile:
الموقع المعني هو https://starzen.space.
لقد نقلته في نهاية هذا الأسبوع إلى https://www.starzen.space باستخدام الدليل هنا
كل شيء سار على ما يرام، ولكن بالطبع ما زلت بحاجة إلى مراعاة العدد القليل من المستخدمين الذين حصلت عليهم حتى الآن في هذا الموقع، لذلك أردت إضافة إعادة توجيه.
وفقًا لفهمي، أحتاج أيضًا إلى الرابط الأصلي الصادر بشهادة، لذلك باتباع هذا الدليل (الذي كان أكثر تعقيدًا في السابق؟) أضفت هذا إلى app.yml:
hooks:
  after_ssl:
    - replace:
        filename: "/etc/runit/1.d/letsencrypt"
        to: "-d starzen.space --keylength"
    - replace:
        filename: "/etc/nginx/conf.d/discourse.conf"
        to: |
          return 301 https://$host$request_uri;
  after_web_config:
    - replace:
        filename: /etc/nginx/nginx.conf
        to: |
          server_names_hash_bucket_size 64;
          sendfile on;
    - file:
        path: /etc/nginx/conf.d/discourse_redirect_1.conf
        contents: |
          server {
            listen 80;
            listen 443 ssl;
            server_name starzen.space;
            return 301 $scheme://www.starzen.space$request_uri;
عند إعادة البناء، يبدو أن كل شيء يسير على ما يرام.
ومع ذلك، إذا حاولت الوصول إلى https://starzen.space عبر المتصفح، أحصل على:
وإذا استخدمت curl:
blah discourse % curl https://starzen.space
curl: (60) SSL: no alternative certificate subject name matches target host name 'starzen.space'
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
أنا متأكد من أن الشهادة هي السبب، لأنه إذا قمت بتشغيل نفس الأمر في وضع غير آمن، أحصل على:
blah discourse % curl -k https://starzen.space
301 Moved Permanently
nginx/1.21.6
وهو ما أعتقد أنه ما أريده.
أعتقد أن ملف البرنامج النصي المعدل صحيح، هذا ما لدي:
root@starship-enterprise:/etc/runit/1.d# cat letsencrypt
#!/bin/bash
/usr/sbin/nginx -c /etc/nginx/letsencrypt.conf
issue_cert() {
  LE_WORKING_DIR="${LETSENCRYPT_DIR}" /shared/letsencrypt/acme.sh --issue $2 -d www.starzen.space -d starzen.space --keylength $1 -w /var/www/discourse/public
cert_exists() {
  [[ "$(cd /shared/letsencrypt/www.starzen.space$1 && openssl verify -CAfile <(openssl x509 -in ca.cer) fullchain.cer | grep "OK")"]]
# RSA cert
issue_cert "4096"
if ! cert_exists ""; then
  # Try to issue the cert again if something goes wrong
  issue_cert "4096" "--force"
fi
<SNIP>
لقد قمت حتى بتشغيل هذا من سطر الأوامر داخل الحاوية، قبل ذلك قمت بنقل جميع ملفات الشهادات من الدليل المستهدف إلى دليل احتياطي حتى يتم تشغيل الأمر الصحيح للنطاق المزدوج:
root@starship-enterprise:/etc/runit/1.d# ./letsencrypt
nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
[Sun 25 Sep 2022 05:50:04 PM UTC] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Sun 25 Sep 2022 05:50:04 PM UTC] Creating domain key
[Sun 25 Sep 2022 05:50:05 PM UTC] The domain key is here: /shared/letsencrypt/www.starzen.space/www.starzen.space.key
[Sun 25 Sep 2022 05:50:05 PM UTC] Multi domain='DNS:www.starzen.space,DNS:starzen.space'
[Sun 25 Sep 2022 05:50:05 PM UTC] Getting domain auth token for each domain
[Sun 25 Sep 2022 05:50:08 PM UTC] Getting webroot for domain='www.starzen.space'
[Sun 25 Sep 2022 05:50:08 PM UTC] Getting webroot for domain='starzen.space'
[Sun 25 Sep 2022 05:50:08 PM UTC] www.starzen.space is already verified, skip http-01.
[Sun 25 Sep 2022 05:50:08 PM UTC] Verifying: starzen.space
[Sun 25 Sep 2022 05:50:12 PM UTC] Pending
[Sun 25 Sep 2022 05:50:15 PM UTC] Success
[Sun 25 Sep 2022 05:50:15 PM UTC] Verify finished, start to sign.
[Sun 25 Sep 2022 05:50:15 PM UTC] Le_OrderFinalize='https://acme-v02.api.letsencrypt.org/acme/finalize/590255196/128806215177'
[Sun 25 Sep 2022 05:50:16 PM UTC] Downloading cert.
[Sun 25 Sep 2022 05:50:16 PM UTC] Le_LinkCert='https://acme-v02.api.letsencrypt.org/acme/cert/03ff6b1b76f8516165032c6c2e02205a529b'
[Sun 25 Sep 2022 05:50:17 PM UTC] Cert success.
-----BEGIN CERTIFICATE-----
Lotsofcrazytext
-----END CERTIFICATE-----
[Sun 25 Sep 2022 05:50:17 PM UTC] Your cert is in  /shared/letsencrypt/www.starzen.space/www.starzen.space.cer
[Sun 25 Sep 2022 05:50:17 PM UTC] Your cert key is in  /shared/letsencrypt/www.starzen.space/www.starzen.space.key
[Sun 25 Sep 2022 05:50:17 PM UTC] The intermediate CA cert is in  /shared/letsencrypt/www.starzen.space/ca.cer
[Sun 25 Sep 2022 05:50:17 PM UTC] And the full chain certs is there:  /shared/letsencrypt/www.starzen.space/fullchain.cer
[Sun 25 Sep 2022 05:50:17 PM UTC] Installing key to:/shared/ssl/www.starzen.space.key
[Sun 25 Sep 2022 05:50:17 PM UTC] Installing full chain to:/shared/ssl/www.starzen.space.cer
[Sun 25 Sep 2022 05:50:17 PM UTC] Run reload cmd: sv reload nginx
ok: run: nginx: (pid 579) 35281s
[Sun 25 Sep 2022 05:50:17 PM UTC] Reload success
[Sun 25 Sep 2022 05:50:18 PM UTC] Domains not changed.
[Sun 25 Sep 2022 05:50:18 PM UTC] Skip, Next renewal time is: Wed 23 Nov 2022 10:01:01 AM UTC
[Sun 25 Sep 2022 05:50:18 PM UTC] Add '--force' to force to renew.
[Sun 25 Sep 2022 05:50:18 PM UTC] Installing key to:/shared/ssl/www.starzen.space_ecc.key
[Sun 25 Sep 2022 05:50:18 PM UTC] Installing full chain to:/shared/ssl/www.starzen.space_ecc.cer
[Sun 25 Sep 2022 05:50:18 PM UTC] Run reload cmd: sv reload nginx
ok: run: nginx: (pid 579) 35282s
[Sun 25 Sep 2022 05:50:18 PM UTC] Reload success
نجاح كبير في الغالب!!!، curl أصبح أكثر لطفًا الآن ويعطيني إعادة التوجيه:
nginx/1.21.6
و https://starzen.space في Firefox و Chrome يعمل الآن، ويعيد التوجيه إلى النطاق الفرعي الصحيح، ولكن ما زلت أحصل على الرسم البياني المروع للموت في Safari، ما الذي يحدث؟ لقد أعدت تشغيله ومسحت ذاكرة التخزين المؤقت لهذا الموقع:
بالنظر إلى الشهادة من المتصفح، أرى:
إعجاب واحد (1)
لقد كنت أنوي إلقاء نظرة فاحصة على هذا. أعتقد أن هناك الآن مكانين في قالب Let’s Encrypt حيث يجب إضافة النطاق الإضافي. لا أعتقد أنك بحاجة إلى إجراء أي تغييرات على إعدادات Nginx لأنها تقوم بالفعل بإعادة توجيه 301 إلى أي شيء بخلاف اسم المضيف.
ما يجب فعله هو النظر إلى قالب Let’s Encrypt ومعرفة أين يضع اسم المضيف والتأكد من أنك تفعل ذلك مع اسم المضيف الإضافي أيضًا.
3 إعجابات
نعم، شكرًا لك، لقد فعلت ذلك من أجل الاكتمال ولا يبدو أن هناك أي ضرر فيه حتى الآن، ولكني سعيد بإعادة بنائه بدونه في مرحلة ما.
يبدو أن هناك مجموعتين من الملفات التشفيرية؟:
root@starship-enterprise:/shared/letsencrypt# cd starzen.space
root@starship-enterprise:/shared/letsencrypt/starzen.space# ls
backup	ca.cer	fullchain.cer  starzen.space.cer  starzen.space.conf  starzen.space.csr  starzen.space.csr.conf  starzen.space.key
root@starship-enterprise:/shared/letsencrypt/starzen.space# cd ..
root@starship-enterprise:/shared/letsencrypt# cd www.starzen.space
root@starship-enterprise:/shared/letsencrypt/www.starzen.space# ls
backup	    ca.cer	   www.starzen.space.cer   www.starzen.space.csr       www.starzen.space.key
backup_two  fullchain.cer  www.starzen.space.conf  www.starzen.space.csr.conf
آه، هل يمكن أن يكون هنا (وما يلي)
إنه يتضمن فقط معلومات لاسم المضيف، وليس القمة؟
إعجاب واحد (1)
لا، أعتقد أن هذا صحيح؟ يجب أن يكون هناك شهادة واحدة ويجب أن تعمل لكل من www. والنقطة الأصلية.
تقترح هذه الأداة أن هناك مجالًا واحدًا فقط على شهادتي العامة (والذي سيكون مصدر المشكلة؟):
إعجاب واحد (1)
تحتاج إلى تغيير الجزء الخاص بـ Let’s Encrypt الذي يحصل على الشهادة. يجب أن يطلب الشهادة الفردية لكلا النطاقين. كانت هذه التعليمات تعمل سابقًا، ولكن شيئًا ما تغير في كيفية طلب الشهادة، على ما أعتقد. إذا حصل على الشهادة الصحيحة، فإن كل شيء آخر يعمل بشكل جيد.
إعجاب واحد (1)
إذا قمت بتشغيل certbot certificates، فسيتم عرض الشهادة (الشهادات) الخاصة بك والنطاقات التي تغطيها. إذا لم تكن تغطي كلاً من النطاق الأساسي (apex) والنطاق www، فيمكنك
  1. تشغيل certbot مرة أخرى وجعله ينشئ شهادة لكل من النطاق الأساسي (apex) والنطاق www؛
إذا اخترت هذا الخيار، فقم بتشغيل certbot certificates للحصول على اسم الشهادة التي تريد حذفها. قم بتشغيل certbot delete (اسم الشهادة التي تريد حذفها). يجب أن تتركك شهادتك الجديدة فقط (مع كل من النطاق الأساسي www).
أو (الأسهل)
2) تشغيل `certbot --expand -d existing.domain -d added.domain
سيؤدي هذا إلى تحديث شهادتك بشهادة جديدة تحتوي على النطاق الأصلي والنطاقات التي تضيفها باستخدام العلامة -d.
إعجابَين (2)
جيم، الأمر certbot غير موجود؟ هل هذا جزء من التثبيت القياسي وهناك مجرد مشكلة في المسار؟
إعجاب واحد (1)
بدون النظر فعليًا… أعتقد أن certbot هو ما تستخدمه عادةً، ولكن داخل الحاوية استخدم discourse acme.
وأيضًا بشكل متعلق، هل تحاول هذا داخل الحاوية أم خارجها؟
(أيضًا يومي يمتلئ وقد لا أتمكن من النظر في هذا بعناية كما كنت أعتقد، ولكنه كان على قائمتي)
3 إعجابات
أتفق … أعتقد أن إحدى الطرق للقيام بذلك هي هذه؟:
إذا استخدمت من أي سطر أوامر لينكس مناسب
true | openssl s_client -connect www.starzen.space:443 2>/dev/null \
| openssl x509 -noout -text \
| perl -l -0777 -ne '@names=/\\bDNS:([^\\s,]+)/g; print join("\n", sort @names);'
أحصل على نطاق واحد فقط وهو يفتقد إلى القمة (apex).
إعجاب واحد (1)
داخل الحاوية تجد الرمز الذي يطلب (ويجدد؟) الشهادة وتكتشف أنه يطلبها لكلا النطاقين.
إعجاب واحد (1)
نعم، كما هو موضح في:
ويمكنك رؤية هذا في مخرجات السجل أعلاه.
ومع ذلك، هناك بعض خطوات تثبيت الشهادة الأخرى التي تتضمن فقط -d www.starzen.space، وقد يكون هذا مشكلة؟ على الرغم من أنه إذا تم إنشاء هذه الشهادة لكليهما، فربما ليست هذه هي المشكلة…
إعجاب واحد (1)
هذا ما كنت أحاول قوله. يبدو أنك بحاجة إلى تحديثها أيضًا. لست متأكدًا لماذا يوجد الآن العديد منها، ولكن يجب تحديث OP بالتعليمات البرمجية لتغيير كل هذه الخطوات. أو هكذا أعتقد.
4 إعجابات
نعم، سأجرب ذلك، يدويًا في البداية
إعجابَين (2)
حسنًا. هذا ما كنت سأفعله. ربما خدعتك لأفعل ذلك. :winking_face_with_tongue:
إعجاب واحد (1)
من المنطقي المحاولة، فقط قد أحتاج إلى إعادة بناء الحاوية لتثبيت nano … :sweat_smile:
إعجاب واحد (1)
لا!
 apt-get uodate;apt-get install nano
يمكنك تشغيل ذلك داخل الحاوية. أنا أفعل ذلك طوال الوقت (باستثناء أنني أستخدم vim)
3 إعجابات
للأسف لم ينجح ذلك:
[Mon 26 Sep 2022 12:35:54 PM UTC] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Mon 26 Sep 2022 12:35:54 PM UTC] Creating domain key
[Mon 26 Sep 2022 12:35:56 PM UTC] The domain key is here: /shared/letsencrypt/www.starzen.space/www.starzen.space.key
[Mon 26 Sep 2022 12:35:56 PM UTC] Multi domain='DNS:www.starzen.space,DNS:starzen.space'
[Mon 26 Sep 2022 12:35:56 PM UTC] Getting domain auth token for each domain
[Mon 26 Sep 2022 12:35:59 PM UTC] Getting webroot for domain='www.starzen.space'
[Mon 26 Sep 2022 12:35:59 PM UTC] Getting webroot for domain='starzen.space'
[Mon 26 Sep 2022 12:35:59 PM UTC] www.starzen.space is already verified, skip http-01.
[Mon 26 Sep 2022 12:35:59 PM UTC] starzen.space is already verified, skip http-01.
[Mon 26 Sep 2022 12:36:00 PM UTC] Verify finished, start to sign.
[Mon 26 Sep 2022 12:36:00 PM UTC] Lets finalize the order.
[Mon 26 Sep 2022 12:36:00 PM UTC] Le_OrderFinalize='https://acme-v02.api.letsencrypt.org/acme/finalize/590255196/129044627717'
[Mon 26 Sep 2022 12:36:01 PM UTC] Downloading cert.
[Mon 26 Sep 2022 12:36:01 PM UTC] Le_LinkCert='https://acme-v02.api.letsencrypt.org/acme/cert/03ffc90cecd2f11f2ba386da2d501127aee5'
[Mon 26 Sep 2022 12:36:02 PM UTC] Cert success.
phewbigcert
[Mon 26 Sep 2022 12:36:02 PM UTC] Your cert is in  /shared/letsencrypt/www.starzen.space/www.starzen.space.cer
[Mon 26 Sep 2022 12:36:02 PM UTC] Your cert key is in  /shared/letsencrypt/www.starzen.space/www.starzen.space.key
[Mon 26 Sep 2022 12:36:02 PM UTC] The intermediate CA cert is in  /shared/letsencrypt/www.starzen.space/ca.cer
[Mon 26 Sep 2022 12:36:02 PM UTC] And the full chain certs is there:  /shared/letsencrypt/www.starzen.space/fullchain.cer
[Mon 26 Sep 2022 12:36:02 PM UTC] Installing key to:/shared/ssl/www.starzen.space.key
[Mon 26 Sep 2022 12:36:02 PM UTC] Installing full chain to:/shared/ssl/www.starzen.space.cer
[Mon 26 Sep 2022 12:36:02 PM UTC] Run reload cmd: sv reload nginx
ok: run: nginx: (pid 2970) 329s
[Mon 26 Sep 2022 12:36:02 PM UTC] Reload success
[Mon 26 Sep 2022 12:36:03 PM UTC] Domains not changed.
[Mon 26 Sep 2022 12:36:03 PM UTC] Skip, Next renewal time is: Wed 23 Nov 2022 10:01:01 AM UTC
[Mon 26 Sep 2022 12:36:03 PM UTC] Add '--force' to force to renew.
[Mon 26 Sep 2022 12:36:04 PM UTC] Installing key to:/shared/ssl/www.starzen.space_ecc.key
[Mon 26 Sep 2022 12:36:04 PM UTC] Installing full chain to:/shared/ssl/www.starzen.space_ecc.cer
[Mon 26 Sep 2022 12:36:04 PM UTC] Run reload cmd: sv reload nginx
ok: run: nginx: (pid 2970) 331s
[Mon 26 Sep 2022 12:36:04 PM UTC] Reload success
مما لا يزال يبدو أنه كشف عن شهادة بنطاق واحد…
| perl -l -0777 -ne '@names=/\\bDNS:([^\\s,]+)/g; print join("\\n", sort @names);'
www.starzen.space
إعجاب واحد (1)
