コミュニティ名の前に奇妙な記号が表示されます
Hello,
I’ve just created my first Discourse site to give my readers and Patrons an alternative place to comment, and I’ve been having a tremendously positive experience, both with Discourse overall and the WP-Discourse plugin.
In my tests, it does everything I hoped it would, including allowing me to keep the Disqus comments under the page in addition to the Discourse comments while I transition my readers over to the new community.
There is only one odd thing I’ve noticed. On my site, the plugin is adding a weird circle-with-an-x symbol before the name of my community, like this:
I’m sure it’s something obvious that I’ve missed, but I’ve checked my settings on my Wordpress site, and I don’t see any extra symbols that I’ve added in the text fields.
I had updated to the latest version of Discourse and this plugin before running my first tests tonight, so I’m running the latest versions of everything.
How should I troubleshoot this?
Any help would be greatly appreciated because, besides this one, weird thing, everything else seems to work like a charm. :slight_smile:
Thanks!
That looks like something added with CSS, perhaps? Did you check your site’s CSS in your browser F12 inspector?
Doesn’t look like anything to do with Discourse.
「いいね!」 4
If you can send me a link to a post that is happening on, I’ll take a look.
Thank you, Simon. I reactivated the plugin. You can find an example on this page:
Just scroll down to just below the big, green Patreon ad. The Discourse comments are just below that.
I appreciate your help with this. Please let me know if you need anything else.
「いいね!」 1
There is some CSS being added by your theme or a plugin with this rule:
.comment-reply-title a:before {
    font: 100%/1 awesome;
    content: '\f057';
    padding: 0 .25rem 0 0;
The easiest thing to do would be to find that CSS and remove it. You could also add a CSS rule that targets .discourse-comments-area .comment-reply-title a:before and sets the content to ''.
「いいね!」 3
