Access real name in quote display
Continuing the discussion from Display real name instead of username in a quote?:
I need for quotes to display the user real name exactly the same way that they are displayed in posts. In this image, “sam:” should be something like “Sam Saffron (sam):”
I think that this would be more consistent, but it matters only if you have meaningless usernames.
My questions:
  • Can I fix this with a theme or will it take a plugin?
  • Can someone point me to a similar example?
This seems like it should be trivial, but I’m lost on this end of things and don’t know where to start.
@codinghorror I wonder if we should switch quotes to full name when the site setting prioritise full name is enabled?
Sure if it is an easy change that is fine
We would absolutely like to see this feature implemented.
これ、本当にやったことあります?@sam
いいえ、まだ完了していません。オートコンプリートポップアップ、作曲者のタイトル、メンションを扱う場合、それなりの複雑な変更が必要になります。
これで動作するはずです。:partying_face:
