I’m dabbling with Discourse themes but am not a web/Javascript developer. Looking at some third-party theme components I’ve got this question.
In discourse-header-submenus/javascripts/discourse/connectors/above-site-header/header-submenus.js, there’s this code:
export default {
setupComponent() {
// some code here
There are no imports at the top of the file.
If I understand (strict
) JavaScript correctly, the only context the code within setupComponent()
will have access to are the attributes of the object it is evaluated on.
When I look at this context using console.log(this)
within the setupComponent()
function, it appears I have no access to the very handy api
object.
That’s a pity!
Also, I wouldn’t know how to import
it correctly since the official wrapper code for using api-functions is versioned and looks like this:
export default apiInitializer("0.12.3", api => {
// code that uses the api here
How could I access the api
object from within setComponent()
? Or am I missing something fundamental here?
