Hello,
I accidentally deleted the Default theme when I was configuring a new theme for a test. Is it possible I can re-add it so I can configure it again?
Hello,
Hello,
You can easily add the Default theme again with creating a new theme on admin like this.
Click the Install button
Click the Create New tab and set name Default to the theme then click Create.
Check in the Theme is enabled by default field and select the Light color palette. (but I believe this will happen automatically)
That’s it! ![]()
It can easily recover by rerun the wizard too. Actually this is a super fast way.
/wizard/steps/stylingThat’s it! ![]()
