haydenjames
(Hayden James)
23 בנובמבר, 2023, 6:40pm
1
If I accidentally deleted the default theme but then restore it using this method:
Hello,
You can easily add the Default theme again with creating a new theme on admin like this.
Click the Install button
[Screenshot 2022-12-23 at 7.13.21]
Click the Create New tab and set name Default to the theme then click Create.
[Screenshot 2022-12-23 at 7.14.09]
Check in the Theme is enabled by default field and select the Light color palette. (but I believe this will happen automatically)
[Screenshot 2022-12-23 at 7.15.00]
That’s it!
It can easi…
… will auto-updates from the theme repo still happen? I don’t see the autoupdates checkbox for the theme anymore. It’s missing:
Where can I redownload the default theme?
RGJ
(Richard - Communiteq)
23 בנובמבר, 2023, 6:45pm
The default theme is just an empty shell so there is nothing to update. The reason you’re not seeing the autoupdates checkbox is because there isn’t even a repo.
haydenjames
(Hayden James)
23 בנובמבר, 2023, 6:49pm
3
Ok I understand. thanks. Will leave as-is then
