Aktivierungs-E-Mails: discourse-doctor funktioniert, discourse selbst nicht
Hi all,
Just as the title says. discourse-doctor will connect to my mailserver (running on the host machine) via its external and internet-facing interface (but not localhost), but discourse itself just will not.
No attempt by discourse is being logged, neither in the Rails production log nor my mailserver logs. I’ve even run a packet sniffer on the Docker interface and see no mail traffic.
discourse-doctor however does produce log entries on my mailserver, as expected, and I can read the email in my mail client.
I have rebuilt the Docker container several times with the following configuration:
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
###   - "templates/web.ssl.template.yml"
###   - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "127.0.0.1:1234:80"   # http
    ###   - "127.0.0.1:1235:443" # https
params:
  db_shared_buffers: "256MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 4
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: example.com
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'me@another.com'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: submission.example.com # A record works but not CNAME
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: somedumbuser
  DISCOURSE_SMTP_PASSWORD: somedumbpass
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: ssl@yetanother.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
  - replace:
      filename: /etc/nginx/conf.d/discourse.conf
      to: |
        set_real_ip_from 0.0.0.0/0;
        real_ip_header X-Forwarded-For;
        real_ip_recursive on;
        types {
So running the mail test at /admin/email doesn’t send a message? Is /sidekiq running? Did you do a standard install?
Discourse needs a domain name to work, so your problem may be related to binding it only to localhost.
Hi Jay, thanks for responding.
When I run sudo docker exec -it app /bin/bash, I don’t see an /admin directory. Nor do I see an /admin directory cloned from the git repo.
pgrep -afl sidekiq does show a process with that name running.
I am running Discourse behind HAProxy, as I described here, hence the binding to localhost: How to install Discourse behind Apache mod_proxy?
I have tried modifying expose as follows and there is still not so much as a SYN being sent to port 587 on my mailserver. DISCOURSE_HOSTNAME is set to the correct domain, sidekiq is running, and still no idea where to find /admin/email.
expose:
  - "1234:80"   # http
/admin/email is a relative path
You need to access it in a web browser:
{Your Discourse Hostname}/admin/email
