Activity column empty
Hi all,
I did the last update → 2.4.0.beta6 and i noticed that the activity column is empty.
I beleive it is because the category column isn’t here either, any idea how to fix it ?
Many thanks
The category column is gone so everything shifted over one to the left.
Eek that’s potentially a Topic List Previews plugin bug. Completely remove TLP if you are not using it. I’ve been meaning to push a fix to swap the logic around so that no Category column is the default.
@merefield yep, it removed it and it is back to normal, thank you.
