הוסף תמונת חתימה למשתמש ספציפי (אני יכול לעשות זאת עבור קבוצה כבר)
סיכום מבוסס בינה מלאכותית
Adding a Signature Picture for a Specific User
Kartoon wants to add a signature picture to specific users’ posts without creating individual groups. They are currently using CSS to add a signature picture to a group, but need help adapting it for individual users.
Kartoon provided their current CSS code and mentioned that swapping .username-User doesn’t work.
Arkshine suggested relying on the user’s ID or username to solve the issue and provided an example using the ID:
.topic-post article[data-user-id="2"] .topic-body .cooked::after {
Kartoon confirmed that this solution worked for them.
I currently have it set up where a certain group has a small image that appears as sort of a signature in every post. I want to expand this to a couple people but I don’t really want to have to make individual groups for everyone (they won’t have the same one so I can’t just make a group for the few of them).
I’m not great with CSS (I can use it and sometimes tinker around a bit but that’s my limit). Right now I’m using
.topic-post.group-Owner .topic-body .cooked::after {
    background-image: url("https://picture.image");
    background-repeat: no-repeat;
    background-size: 160px 80px; /*change these values according to the image size*/
    width: 160px; /*change this value according to the image size*/
    height: 80px; /*change this value according to the image size*/
    display: block;
    float: right;
    content: "";
Which works fine for the group. I’ve tried swapping .username-User and that doesn’t work.
Hey,
If you look at the HTML structure, you can see the following:
You can rely on the user’s ID or username (but likely less reliable).
For example, with the ID:
That did it, thank you!
