Agregar panel de menú personalizado a la ubicación correcta (igual que el panel del menú hamburguesa)
In Reuse Discourse Hamburger Functionality - #5 by awesomerobot, a way to add a new menu item to the header-icons location (i.e. where Discourse hamburger menu is located) is described.
In essence, a call to api.decorateWidget('header-icons:after', callback) is used to (1) add an additional menu entry with its own icon and (2) add a menu panel if its underlying state variable for its visibility is true.
This works, but is slightly inconsistent with the way Discourse’s existing menu entries work: The new menu is added as a child to the header-icons location (i.e. the div.d-header-icons element), while Discourse’s menus are children of div.panel (i.e. the parent element of div.d-header-icons).
This difference causes the added menu to be occluded by the div.header-cloak element for the mobile view.
Is there a way to add a widget to div.panel? Alternatively, is there a chance that the element div.panel will be available as a widget location?
I found a solution to this issue. The missing piece was the api.addHeaderPanel method. I’m not quite sure why its third argument, a callback, has to be provided, but passing a do-nothing function works.
Anyway, a theme component with the following files allows one to add a Discourse menu entry and panel in the correct locations that works in both desktop and mobile views.
./common/head_tag.html:
The following pieces of JavaScript are all part of this script element:
</script>
First, I’m setting up a data structure that contains the content of the new menu:
const { h } = require('virtual-dom');
const { attachAdditionalPanel } = require('discourse/widgets/header');
const menuItems = [
        text: 'Home',
        href: '/'
        text: 'FAQ',
        href: '/faq'
Second, I’m creating a new widget called custom-menu. This follows what Discourse uses for its own hamburger menu (see app/assets/javascripts/discourse/widgets/hamburger-menu.js.es6).
api.createWidget('custom-menu', {
    tagName: 'div.custom-panel',
    settings: {
        maxWidth: 320
    panelContents() {
        return h(
            'ul.custom-menu',
            menuItems.map(item => h('li', h('a', { href: item.href }, item.text)))
    html() {
        return this.attach('menu-panel', {
            contents: () => this.panelContents(),
            maxWidth: this.settings.maxWidth
    clickOutside(event) {
        if (this.site.mobileView) {
            this.clickOutsideMobile(event);
        } else {
            this.sendWidgetAction('toggleCustomMenu');
    clickOutsideMobile(event) {
        const centeredElement = document.elementFromPoint(event.clientX, event.clientY);
        if (
            !centeredElement.classList.contains('header-cloak') &&
            centeredElement.closest('.panel').length > 0
        } else {
            const panel = document.querySelector('.menu-panel');
            panel.classList.add('animate');
            const panelOffsetDirection = this.site.mobileView ? 'left' : 'right';
            panel.style.setProperty(panelOffsetDirection, -window.innerWidth);
            const headerCloak = document.querySelector('.header-cloak');
            headerCloak.classList.add('animate');
            headerCloak.style.setProperty('opacity', 0);
            console.log('hi')
            Ember.run.later(() => this.sendWidgetAction('toggleCustomMenu'), 200);
Next, I add a new entry to Discourse’s top menu bar (where the search icon, hamburger menu, and the user menu are located). I also setup a widget action that is responsible for changing the state variable that controls the visibility of the custom menu.
api.decorateWidget('header-icons:after', function (helper) {
    const headerState = helper.widget.parentWidget.state;
    return helper.attach('header-dropdown', {
      title: 'custom-menu',
      icon: 'bars',
      iconId: 'toggle-custom-menu',
      active: headerState.customMenuVisible,
      action: 'toggleCustomMenu',
api.attachWidgetAction('header', 'toggleCustomMenu', function() {
    this.state.customMenuVisible = !this.state.customMenuVisible;
Finally, the following line adds the custom-menu widget to the correct location in the DOM depending on whether the state variable customMenuVisible is true.
api.addHeaderPanel('custom-menu', 'customMenuVisible', function (attrs, state) {
    // This callback has to be provided. Don’t know why.
(Again, all these JavaScript blocks belong into the script element above.)
./common/common.scss:
This stylesheets just adds some missing styles that the other panels use.
.d-header .custom-panel {
  width: 0;
.mobile-view .custom-panel .menu-panel.slide-in {
  left: 0;
He estado dando vueltas a esto durante un tiempo. El título del menú hamburguesa personalizado muestra la información de la configuración regional, de modo que al pasar el ratón por encima del menú, obtengo lo siguiente:
[en_US.some-title]
Al intentar usar I18n.t(themePrefix("some-title")) después de crear un tema con un archivo de configuración regional, obtengo lo siguiente:
[en_US.Some Title]
Tal como se muestra
api.decorateWidget('header-icons:before', function (helper) {
      title: "mysite.menu_title",
      icon: 'bars',
      href: ""
Tema con il8n
      title: I18n.t(themePrefix("mysite.menu_title")),
      icon: 'bars',
Aquí está mi código completo del script. El tema y el CSS son los predeterminados para un tema recién generado usando discourse_theme new.
Resumen
const { iconNode } = require("discourse-common/lib/icon-library");
const mySiteAboutLinks = [
            text: "Knowledgebase",
            rawTitle: "Knowledgebase",
            href: "/k",
            className: "mysite-about",
            icon: "question"
    const mySiteSupportLinks = [
            text: "Staff",
            rawTitle: "Staff",
            href: "/page/staff/1/",
            className: "mysite-support",
            icon: "link"
            text: "Contact",
            rawTitle: "Contact",
            href: "/page/contact/2/",
            icon: "far-envelope"
    settings: {
        maxWidth: 320
    panelContents() {
        results = [];
        results[1] = h('ul.custom-about-menu.menu-links.columned', mySiteAboutLinks.map(l => h('li', h('a.widget-link', { href: l.href, title: l.rawTitle }, [ iconNode(l.icon.toLowerCase()), ' ', h('span.d-label', l.text) ]))));
        results[2] = h('div.clearfix');
        results[3] = h('hr');
        results[4] = h('ul.custom-support-menu.menu-links.columned', mySiteSupportLinks.map(k => h('li', h('a.widget-link', { href: k.href, title: k.rawTitle }, [ iconNode(k.icon.toLowerCase()), ' ', h('span.d-label', k.text) ]))))
        return results;
    html() {
        } else {
        if (
        } else {
            console.log('hi')
      icon: 'bars',
    // Esta función de callback debe ser proporcionada. No sé por qué.
¿Alguna idea sobre cómo corregir el título al pasar el ratón para que solo se muestre el título sin corchetes ni información de la configuración regional?
:fist:
Lo revisé y estoy bastante seguro de que esto no es culpa tuya; el código que estás usando debería funcionar.
El problema aquí es que el atributo title del widget de menú desplegable del encabezado espera una clave de traducción, no una función de traducción.
Así que cuando usas esto en un tema:
estás esencialmente anidando dos funciones de traducción.
La de tu tema devuelve la cadena que hayas definido en el archivo de localización. En este caso es:
Some title
La del código del widget toma esa cadena y la procesa como una clave de traducción de la siguiente manera:
I18n.t('Some title')
lo cual, obviamente, no existe, por lo que ves el problema que reportaste, donde devuelve:
[en_US.Some Title]
En otras palabras, esto es un error en el núcleo. Lo arreglaremos :+1:
¡Eso es bueno saberlo! ¿Alguna idea sobre por qué el código proporcionado también devolvería tal problema?
Revisé el historial y puedo afirmar con cierta seguridad que no hubo cambios en ese archivo entre el momento en que se publicó ese mensaje y el momento en que hiciste tu pregunta que fueran relevantes aquí.
Mi suposición es que, incluso con el código tal como está, habrías obtenido
[en_US.custom-menu]
al pasar el cursor sobre el enlace si agregas
como se indica en el código proporcionado anteriormente por kleinfreund.
Quizás simplemente nunca notaron ese problema.
También, si deseas una solución temporal mientras tanto, puedes combinar el método antiguo (antes de las traducciones de temas) con el nuevo:
I18n.translations.en.js.custom_translation = I18n.t(themePrefix("custom_theme_translation"));
  title: 'custom_translation',
¡Gracias por tus comentarios, @Johani! Y eso funciona de maravilla, @awesomerobot. ¡Lo aprecio mucho! Esas respuestas funcionaron mejor que yo dándome golpes en el teclado con la cabeza y/o tomando Motrin.
Actualización: El enfoque anterior dejó de funcionar recientemente y estoy trabajando en determinar qué sucedió. Si alguien conoce otra publicación que cubra cualquier cambio, me encantaría leerla.
