Riutilizza la funzionalità Hamburger di Discourse
Hello Discourse Team!
I am using the discourse CLI Install the Discourse Theme CLI console app to help you build themes and the plugin API A versioned API for client side plugins to help me create my theme.
I have added a custom header in the header.html file. On mobile, I was hoping to create a hamburger menu that functions like discourse’s hamburger
But has completely different menu contents.
I could create the hamburger and menu with my knowledge of css/html/js. But I was hoping for a way to use the functionality that discourse has already implemented (opening, closing, etc..).
Any suggestions on how to achieve this?
  • I thought maybe I would be able to extend the widget for the current navigation, change the settings, then attach it to the html I have written for my nav. But the connectors seemed to be predefined, and I wasnt sure how to connect my widget to my html. This might not be the right direction at all either…
Okay, so I think I have a better understanding on what I am trying to do.
I would like to create a connector where I can connect to one of the elements that I have added to the page.
I’m guessing this isn’t possible???
The plugin API (https://github.com/discourse/discourse/blob/master/app/assets/javascripts/discourse/lib/plugin-api.js.es6#L11) has api.registerConnectorClass but I cannot seem to figure out how to connect this to my custom element.
The Brand Header might give you some ideas about how to approach this. You can find its code here: GitHub - discourse/discourse-brand-header: Brand header theme component for Discourse · GitHub. It only displays a hamburger menu in mobile mode. You can get the mobile view on a desktop by appending
?mobile_view=1 to your forum’s URL.
This is slightly rough but should get you 99% of the way there when it comes to having an additional menu item with a dropdown panel. Calling this one a pizza menu :pizza:. Add this to your header.html file.
api.createWidget('pizza-menu', {
  tagName: 'div.pizza-panel',
  panelContents() {
    return "hello world";
  html() {
    return this.attach('menu-panel', {
      contents: () => this.panelContents()
  clickOutside() {
    this.sendWidgetAction('togglePizza');
api.decorateWidget('header-icons:after', function(helper) {
  const headerState = helper.widget.parentWidget.state;
  let contents = [];
    contents.push(helper.attach('header-dropdown', {
      title: 'pizza-menu',
      icon: 'cutlery',
      active: headerState.pizzaVisible,
      iconId: 'toggle-pizza-menu',
      action: 'togglePizza',
    if (headerState.pizzaVisible) {
            contents.push(helper.attach('pizza-menu'));
    return contents;
api.attachWidgetAction('header', 'togglePizza', function() {
  this.state.pizzaVisible = !this.state.pizzaVisible;
</script>
Yes! This is very close!
My only concern was the connect part:
What if I wanted to add the pizza menu to a custom HTML element (defined in common/head_tag.html)?
Ah ok in that case you’re looking at something more like what @simon mentioned in the brand header theme component, I was attaching the action to the existing header widget… the brand header adds it to a new one. The new widget here w/ toggleHamburger:
 api.createWidget('brand-header', {
    tagName: 'header.b-header.clearfix',
    buildKey: () => `header`,
    defaultState() {
      let states =  {
        hamburgerVisible: false
      return states;
    toggleHamburger() {
      this.state.hamburgerVisible = !this.state.hamburgerVisible;
and then the action is added to an HTML element in another widget here
api.createWidget('brand-header-icons', {
    tagName: 'ul.icons.clearfix',
    buildAttributes() {
      return { role: 'navigation' };
    html(attrs) {
      const hamburger = this.attach('header-dropdown', {
                              title: 'hamburger_brand_menu',
                              icon: 'bars',
                              iconId: 'toggle-hamburger-brand-menu',
                              active: attrs.hamburgerVisible,
                              action: 'toggleHamburger'
      const icons = [hamburger];
      return icons;
Thank you for this code. Can you point me in the right direction on filling out the panelContents? I see some indication, but not sure how it all links together.
Ciao! So che questo è un argomento vecchio, ma è quasi quello che sto cercando di fare. Quindi, posto qui (invece di creare un nuovo argomento). Tieni presente che non sono uno sviluppatore, non so come funzionano i plugin e non so scrivere JavaScript. Ma so come copiare e incollare il codice :wink:
Quello che sto cercando di fare è aggiungere un accesso a una chatroom all’interno di un menu a tendina. Quindi, voglio un’icona “chat”, e nel menu a tendina ci saranno un campo di input, un pulsante di invio e qualche testo di aiuto o un link alla pagina di aiuto.
Posso adattare il tuo codice, sostituendo l’icona delle “posate” con un’icona “chat”? Come si fa?
In secondo luogo, come posso inserire codice HTML invece della frase “hello world”? (In pratica, come si inserisce HTML lì dentro?)
Grazie mille in anticipo!
In relazione al post di Queth, è possibile inserire un link aggiuntivo subito prima di FAQ nel pannello a discesa?
Questo componente potrebbe funzionare. Bisogna solo spostare il link personalizzato subito prima di FAQ
https://meta.discourse.org/t/custom-hamburger-menu-links/87644/41
haha, per caso sto guardando esattamente la stessa cosa anch’io. Penso che il modo migliore sia riaprire il widget del menu hamburger e sovrascrivere il metodo html.
Userò unshift per inserire il mio widget prima della sezione FAQ. Non ho verificato se funziona, ma sarà il mio approccio :smiley:
Qui sembra funzionare
  api.reopenWidget("hamburger-menu", {
      html() {
        let conti = this.panelContents()
        conti.unshift(h('div',[h('span','blabla description: '),this.attach('widget-dropdown',
  {id: "from", translatedLabel: "bla",onChange: "changeaction",
  content: [
      { id: 1, label: "foo.bar" },
      { id: 2, translatedLabel: "FooBar" },
      { id: 3, label: "foo.baz", icon: "times" },
      { id: 4, html: "<b>foo</b>" },
    options: {bodyClass: "lang-drop-body"}
        return this.attach("menu-panel", {
          contents: () => conti,
          maxWidth: this.settings.maxWidth
Ho aggiunto un menu a tendina come esempio.
ciao
Ciao, come posso posizionare questo subito dopo l’icona di ricerca? E come posso aggiungere HTML personalizzato all’interno di panelContents?
