Could I enable Q&A for a category? In detail, if I have enabled Q&A for a category, all the posts under this category would show this vote widget and no need (or forbid) to toggle it for each topic.
I’ve just had a quick check and it appears the Q&A toggle is currently at the post level, and not at the category level. This would mean that each topic would have to be flipped to a Q&A style one when it’s first created.
It’s an interesting point though. I can see a use for a setting or two at the category level.
This is certainly a great suggestion @techAPJ , we should add to the list, it lowers the barrier to entry here.
Note though, there are complexities we can easily skip for v0 (eg: created in category A and moved to Q&A category B) … I would say v0 is mix-and-match, it simply “auto toggles” if you make a new topic in the category, nothing more.
That will be a great starting point. Thank you for considering it.
Please enable Q&A for a category, this will make it easy for people to use this feature.
In the meantime, could we simply drop in some JS to automatically trigger the switch to the Q&A format? Whatever JS is triggered when clicking on “Toggle Q&A,” we simply execute on page load without the click event?
For me, I’m not even concerned about specifying a category; I merely want all topics to default to the Q&A format.
@techAPJ This is a feature a client of ours needs and I’d be happy to make a PR unless you have specific plans for this already?
The feature is not on my priority list right now. PR is welcome! ![]()
@angus — So, there’s an existing feature when editing a category’s settings:
Make new topics wikis by default
We can expect this new feature to be enabled there once it’s ready?:
Make new topics Q&As by default
Or wait, the protocol is that it’ll have to be under Settings > Plugins?
Yes, it will be a category-level setting.
I’ve just made a draft PR for this setting for @techAPJ 's initial review.
Update: The PR has been merged
Thanks @techAPJ ![]()
There’s now a category level setting to create QA topics by default in the category. Go to a category’s settings and check “New topics default to Q&A in this category.” under “Question Answer”.
The conversation to extend this setting to be an enforced topic state can be found in Limit all topics in a category to be Post Voting
