Add setting to disable hotlinking of large image files
Lets see:
3 curtidas
@vinothkannans the 1 on both sides is confusing
1 curtida
Also there should be an alt="image too large to display" tooltip on that, for mouse-capable devices. That will need to be translated but we do this in a bunch of places already.
3 curtidas
I linked large image placeholders to the original external image url. The above problem comes when that image is already linked. Then the html structure got broken since it have two links.
So what if the large image already linked. Should I skip by not linking again with original image url?
Also go with grey for both icons, not blue or black. This is more correct and more color scheme neutral.
1 curtida
Currently it is with default text color. Okay I will change it to gray.
1 curtida
Hmm how is blue the default text color? Do you mean default link color?
1 curtida
Yeah, it is pulling it from the a and a:visited rules.
2 curtidas
Yes. Since it is font icon colors automatically comes from text colors.
I will do both of it on new PR. Also I am waiting for a solution to below problem. Can you @codinghorror or @sam suggess me any way to handle this situation.
If skipped then user can’t see the image at all.
I am not following what you are asking here. I would like the tooltip and color changes to go in ASAP.
1 curtida
Would it be possible to skip the linking only if the image is already linked?
But thinking about it, is it even possible to hotlink an image and add a link to it?
I don’t think it’s possible with Markdown, or is it? Maybe HTML works?
http://img0.joyreactor.cc/pics/post/%D0%B3%D0%B8%D1%84%D0%BA%D0%B8-superjail-%D0%BC%D1%83%D0%BB%D1%8C%D1%82%D1%81%D0%B5%D1%80%D0%B8%D0%B0%D0%BB-%D0%A1%D0%B2%D0%BE%D1%8F-%D0%B0%D1%82%D0%BC%D0%BE%D1%81%D1%84%D0%B5%D1%80%D0%B0-1886210.gif
No, it doesn’t. Could you show me an example where this is an actual problem?
So, I’d say, just make sure that there is only one link to the image in the cooked post and that is has the rel="noflooow noopener" set.
Okay. I will do both of it ASAP.
The problem I am trying to explain is
Let’s say example.com/image.jpg is larger image than allowed size.
<img src="http://example.com/image.jpg">
Above RAW will be cooked as
<a href="http://example.com/image.jpg">
  <span class="large-image fa fa-picture-o"></span>
</a>
Now the problem comes when the image already linked in RAW like below
<a href="http://google.com">
</a>
Example:
I linked above image to google.com.
Yes. It is possible when we cooking it as HTML.
3 curtidas
Now the above example image is changed as
<a href="http://google.com" rel="nofollow noopener"></a>
<a href="EXAMPLE_URL" target="_blank">
</a>
Would it be possible to change
</a>
into this?
<a href="http://google.com" rel="nofollow noopener">http://google.com</a>
<a href="http://example.com/image.jpg" rel="nofollow noopener" target="_blank">
</a>
1 curtida
Yes. It is possible to cook the HTML like your example.
4 curtidas
I believe this is mostly complete because large images don’t embed, and show a warning now courtesy of @vinothkannans – what do you think @sam?
(the following is a 5.26mb, 3264×2448 image)
Ainda estou observando um comportamento indesejado.
Crie uma postagem com o único conteúdo sendo: “Imgur: The magic of the Internet”
Comportamento esperado:
  • A imagem não tem miniatura e é exibida apenas como um link de texto, ou a imagem é servida a partir de uma URL https.
Comportamento atual:
  • Aviso de conteúdo misto do Chrome e o ícone de cadeado desaparece da página
Hold on, it actually does the correct behavior, but only after page refresh.
Why would you explicitly link to the http version when the https version also works? I feel like this is a totally different request unrelated to what we implemented.
Yes this is working, going to close this as complete.
2 curtidas
