Unterstützung für Block-Level-Kursiv und Fett in BBCode hinzufügen
Consider this text:
[i]
Italic - First line
Italic - Second line
[/i]
It renders as:
Italic - First line
Now consider the same text with an empty line:
[i]
Italic - First line
[/i]
It renders as:
[i]
Italic - First line
[/i]
(the BBCode fails)
Is this the intended behavior?
1 „Gefällt mir“
I don’t think [i] is intended as multi-line markup? In other words, do this:
[i]Italic - First line[/i]
[i]Italic - Second line[/i]
3 „Gefällt mir“
AFAIK, BBCode is not fully specified to cover this but all the relevant BBCode examples are on single lines. So it is unlikely to be a bug.
The normal way to enable multi-line tagging is to add HTML breaks <br/> to make the extra lines explicit between the tags. That works here too:
bbcode [i] italic with <br/> <br/> html line break [/i] example.
bbcode italic with
html line break
example.
2 „Gefällt mir“
@Remah, adding a &nbsp; also works:
[i]
Italic - First line
&nbsp;
[/i]
Renders as:
Italic - First line
@codinghorror, I think you’re right, as the following markup doesn’t have the issue:
[code]
Code block - First line
Code block - Second line
[/code]
2 „Gefällt mir“
Yeah italic bbcode block is not implemented as a multiline. This is current intended behavior. Same goes for bold. The reason I did this is that <i> and <b> also are treated as inline vs block level tags in html.
I am open to expanding this use case if there are enough requests for it, but as it stands it is behaving as designed.
3 „Gefällt mir“
Writing multiple paragraphs of italic / bold text without putting in the effort to put the formatting tag on every paragraph is one of the kinds of low effort-to-annoyance-ratio forum posts that I don’t think should be encouraged.
7 „Gefällt mir“
