Bug with [code]anything[/code] on a single line by itself
Hi,
Our forum has a lot of [code][/code] in its topics, imported from our old phpbb3 forum. One of our user reported a couple of bugs with [code][/code]. For example, this:
A single line of code without newline looks as a grey thick line:
[code]TString option = GetOption();[/code]
Gives:
And in this other example, the -- ----------------------------------------------------------- line gives another issue:
[code]hatiden@ubuntu:~$ gedit ~/.bashrc
hatiden@ubuntu:~$ cd /home/hatiden/garfield/
hatiden@ubuntu:~/garfield$ ls
[/code]
Cheers, Bertrand.
3 лайка
Discourse supports the BBcode but You need a line break after [code] block for it to work.
eg:
[code]
Well, not really, for example a line with embedded TString option = GetOption(); works just fine…
see:
2 лайка
Thanks!
Does that mean that our (old) imported code will stay unreadable with
single line examples code not having newline
It means you are going to need to apply some sort of processor on the old imported code if you want multiline bbcode to be converted from:
some text [code]
test
[/code] test
to:
some text
[code]
test
[/code]
test
It is quite a fiddly transform and I did not want it included in core.
If I were to attack this on an old imported corpus I would apply a transform to the posts raw column that inserts the missing newlines and then run a full rebake.
3 лайка
Thanks for the info, even if this is not exactly the issue we have… (multiline works quite well)
I have no idea what you’re talking about, but thanks anyway for the tips
Multiline works well as long it is not mixed!
This works:
[code]
test
test
[/code]
This does not:
a [code]
test
test
[/code]
This does not:
[code]
test
test
[/code]a
This does not:
[code]a
test
test
a[/code]
4 лайка
Oh, OK, I see. Well, I think our main issue now is the single line one (as in my first post)
I wasn’t even aware of the one you describe, so I suppose there should not be many…
2 лайка
If there are not many, I would recommend installing the Discourse Data Explorer. Then you can find them and fix by hand. You just need to figure out the magic regex.
1 лайк
I will try (maybe), thanks. But the single line ones are many… would that tool be a solution?
Single line should work fine!
Single line should [code]work fine[/code]!
It only gets complicated when you start mixing.
1 лайк
Is this example considered as
mixing?
[code]mixing?[/code]
I would say this snippet not being handled correctly is a bug
It happens due to complications with optional newline handling in CommonMark
4 лайка
OK, so this was my original question, thanks! :slight_smile:
Sure, be sure to edit the OP to talk about the specific example. I can have a look at it.
This is fixed now per:
https://github.com/discourse/discourse/commit/a0cd54750cca2866dfa978858c21c1a88a09899b
7 лайков
Cool! Thank you very much!
