I added a route through a plugin in my plugin.rb
post “/generate” => “discoursegen#generate”
which is running fine however when I do an ajax call on it the route wants me to use an api key? How can I set the route to be open access without auth?
Thanks, Aedan.
skip_before_filter :ensure_logged_in in the controller should do it, assuming you want all endpoints of that controller to be unauth’d.
That sorted it out. Cheers.
