Please bare with me here - first time developing a Discourse plugin. Was thrown into this project by my job…
Background:
This is a continuation of this post. For clarity, I’ll repeat the background here.
My company runs an internal Discourse Forum, as well as an internal WordPress site. The forums are configured to use SSO from the WordPress instance. On the forums, there is a category called “Updates”. On the WordPress side, when a user logs in there is the following PHP function:
$results = $this->_getRequest("c/updates.json", null, $username);
The $results are then parsed. For each topic, if the last_read_post_number < highest_post_number then we assume the user hasn’t fully read the topic and display an excerpt of the topic in a div on the WordPress site. In the div, there is an X. The intention is that clicking the X will set the user’s last_read_post_number equal to the highest_post_number so it is “read” in the forums too.
This was initially set up over a year ago by adding a custom controller and route to make the last_read_post_number. Problem is the route was set in a way that overwrote the Discourse routes.rb file, causing intermittent and eventually permanent problems. In the old topic I asked if there was a way to do this via the API, so I could integrate the code into WordPress. After chatting with engineering, it was determined that the PHP/JS code for the alerts were written by a previous contractor and were not going to be touched as they currently work.
As such, I’m now looking to recreate the old setup “properly”, which I’m assuming means a plugin. The old setup added two files via app.yml
run:
- replace:
filename: "/etc/nginx/conf.d/discourse.conf"
to: client_max_body_size 512m;
- exec: cp /shared/routes.rb /var/www/discourse/config/routes.rb
- exec: cp /shared/staff_corner_controller.rb /var/www/discourse/app/controllers/staff_corner_controller.rb
/shared/routes.rb
A 1±year-old copy of the Discourse routes.rb file with get "staffcorner/mark-read/:pulseUserId/:topicId" => "staffcorner#mark_read" added to the Discourse::Application.routes.draw do section.
class StaffcornerController < ApplicationController
skip_before_filter :check_xhr, :redirect_to_login_if_required
skip_before_filter :require_login
def mark_read
pulseUserId = params[:pulseUserId]
topicId = params[:topicId]
sso_record = SingleSignOnRecord.where(external_id: pulseUserId).first
#wsUrl = SiteSetting.pulse_ws_url
# No record yet, so create it
if (!sso_record)
# Load Pulse roles
res = Net::HTTP.post_form(URI('http://webservices.idtech.com/StaffCorner.asmx/GetUserInfoByUserID'), {'Authenticate' => '{REDACTED}', 'companyID' => '1', 'userID' => pulseUserId})
data = XmlSimple.xml_in(res.body)
userData = data['diffgram'][0]['Result'][0]['User'][0]
email = userData['Email'][0]
username = email
name = userData['FirstName'][0]
user = User.where(:email => email).first
user = user || sso_record.user
topic = Topic.find(topicId)
if (!topic)
render :json => {success: false, message: "Unknown topic"}
return
topicUser = TopicUser.where(:user_id => user.id, :topic_id => topic.id).first
if (!topicUser)
topicUser = TopicUser.create(:user => user, :topic => topic, :last_read_post_number => topic.posts.last)
topicUser.last_read_post_number = topic.posts.last.id
topicUser.save
render :json => {success: true}
I’ve tried implementing this as a plugin, but I’m not suceeding… Here’s what I’ve got at the moment.
Structure:
/staff-forum-plugin
..plugin.rb
../app
..../controllers
....../staff_corner_controller.rb
../config
....settings.yml
..../locales
......server.en.yml
plugin.rb:
# name: staff-forum-plugin
# about: Adds a route for staff corner to mark topics as read
# version: 0.1.0
# authors: Joshua Rosenfeld
# url: {Internal}
enabled_site_setting :mark_read_enabled
after_initialize do
module ::StaffForumsMarkRead
class Engine < ::Rails::Engine
engine_name "staff_forums_mark_read"
isolate_namespace StaffForumsMarkRead
require_dependency 'application_controller'
class StaffForumsMarkRead::MarkReadController < ::ApplicationController
before_action :ensure_plugin_enabled
def ensure_plugin_enabled
raise Discourse::InvalidAccess.new('Staff Forums Mark Read plugin is not enabled') if !SiteSetting.mark_read_enabled
Discourse::Application.routes.append do
staff_corner_controller.rb:
Same as above
settings.yml:
plugins:
mark_read_enabled:
default: true
client: true
server.en.yml:
en:
site_settings:
mark_read_enabled: "Allow Staff Corner important updates banner to mark topics as read?"
Any thoughts, ideas, etc. would be much appreciated. This worked (at least it accomplished what it was supposed to do) when the files were copied as part the app.yml custom commands - but doing this broke the site, so I just need to figure out how to add the files the correct way.
