Adding a date parameter
Discussing the topic “Adding a date parameter”, JammyDodger shares a SQL query that counts the total number of posts in each category within a specific date range. The query utilizes date parameters :start_date and :end_date for future-proofing and uses the date parameter style for intuitive input. Casting the created_at timestamp as a date is also recommended to ensure accurate results.
Jagster encounters a PG::SyntaxError due to inline comments next to the parameters. JammyDodger resolves the issue by removing the comments, providing an updated query that works as expected.
Often you will want to pull out data for a specific time period. You can do this by hard-coding in your time period into the query itself, but to make your report more future-proof you can add a date parameter:
This query is designed to count the total number of posts in each category (excluding deleted posts and topics, private messages, and topics without a category) that were created within a specific date range, and then order the categories by the total number of posts in descending order.
-- [params]
-- date :start_date -- This is a parameter for the start date of the range
-- date :end_date -- This is a parameter for the end date of the range
SELECT
   t.category_id,
   COUNT(p.id) AS "Total Posts" -- Count the number of posts in each category
FROM posts p
  JOIN topics t ON t.id = p.topic_id
WHERE p.created_at::date BETWEEN :start_date AND :end_date -- Filter posts that were created between the start date and the end date (::date casts the created_at timestamp as a date)
  AND t.deleted_at IS NULL
  AND p.deleted_at IS NULL
  AND t.archetype <> 'private message'
  AND p.user_id > 0
  AND t.category_id IS NOT NULL
GROUP BY 1
ORDER BY 2 DESC
Using the parameter style date rather than string makes entering the parameter value much more intuitive, especially when shared with others.
Another notable tip for this type of query is to cast the created_at as a date. As the value is stored in the database as a timestamp, if you don’t cast it to a date the query won’t pick up the results from the date of the :end_date itself.
You can check which values are stored as timestamps using the Explorer tree:
This query is mainly an example to demonstrate the principles. Hopefully you find it useful, but if you have any questions please ask them below. :slight_smile:
PG::SyntaxError: ERROR:  syntax error at or near ":"
LINE 16: WHERE p.created_at::date BETWEEN :start_date AND :end_date -…
:tired_face:
Ah yes, it doesn’t like those inline comments next the parameters.
-- [params]
-- date :start_date
-- date :end_date
SELECT
   t.category_id,
FROM posts p
  AND p.user_id > 0
GROUP BY 1
ORDER BY 2 DESC
This one seems to work better. :+1: (You may need to refresh the page the first time to pick up the parameter input boxes)
Thanks for helping me de-bug the guides. :slight_smile: :trophy:
