¿Añadir un archivo a la carpeta raíz web de Discourse?
A service I use needs to verify ownership of my website by asking me to create a text file with a string in the web root folder:
https://mydiscoursewebsite.com/verify.txt
So I
cd /var/discourse,
then ./launcher enter app
do I just create the file in that folder or navigate elsewhere?
You should create the file anywhere and then move it to root using Putty (SSH)
Simply to myIpaddress/root? Or should I look for some docker-specific web root folder? Sorry about the stupid questions…
This is not possible. You need to verify through DNS records.
Thank you for clearing this up!
