Adding a new Avatar Size in Admin Settings
In Admin Settings you can specify different avatar sizes. On our altered Discourse profiles, I set the height and width of the image to be 220px. The image looks a bit pixelated.
If I stick 220 in avatar sizes, will this help? :slight_smile:
I think it should work with sizes < 1000.
Thanks for that info. So if I put in 220 for example, do I need to run anything to change images on the site? Or will it only work for all future users.
Also, wondering about this:
For avatars uploaded to Discourse, it says the natural size is 240 x 240, but if you put the width and height to this, it doesnโ€™t look as crisp.
This is just my old gravatar being bad.
Ok, so technically, assuming everything is working well, I can set a new avatar size and uploaded images will be stored in that size as well.
