Neotinker
(Ralph Schaffner)
8 Abril, 2019 22:02
1
I’ve modified the onebox github_blob engine to display the stl model file using github’s render url.
https://github.com/discourse/onebox/pull/401
This is my first attempt at modifying onebox. Feedback is welcome.
I’m testing with “Mendel90/dibond/stls/x_motor_bracket.stl at master · nophead/Mendel90 · GitHub ” but that repo is full of stl files that you can test with.
Neotinker
(Ralph Schaffner)
8 Abril, 2019 22:10
Looks like the automated tests that are failing for onebox are failing since the version bump.
https://github.com/discourse/onebox/commit/6ab57eca8cf3d9ee8f7675bf5bd125403c00269b
Neotinker
(Ralph Schaffner)
9 Abril, 2019 00:41
3
@zogstrip @maja Can someone take a look at travis-ci and tell me why the tests are failing?
maja
(Maja)
9 Abril, 2019 07:01
4
Gemfile.lock wasn’t updated with a new version after version bump, it should work now: update Gemfile.lock · discourse/onebox@d0f99c5 · GitHub
Neotinker
(Ralph Schaffner)
9 Abril, 2019 15:55
5
Thanks. Since my pull request is still showing a travis-ci failure, should I close it and recreate it?
mcdanlj
(Michael K Johnson)
11 Abril, 2019 02:55
6
Thank you! I was just wishing for this today because I wanted to display as a model:
https://github.com/johnsonm/lathe-tool-models/blob/master/square-tool.stl
…and a visual model would be more compelling than the textual content!
Neotinker
(Ralph Schaffner)
12 Abril, 2019 15:19
7
The current version does nothing to set the size of the iframe window so the rendered model is fairly small.
I initially thought that was ok since clicking on the link will take you to a page with a larger version of the rendered model but now I’m wondering if the embedded display should be a little larger.
Looking at the youtube plugin, it uses 480x360 which seems like a good size.
It makes me wonder if I should set the default size to 480x360 or leave it as it is.
mcdanlj
(Michael K Johnson)
13 Abril, 2019 20:37
8
As someone who creates models and intends to use this feature, I think that the 480x360 is a more meaningful aspect ratio for interactive content like this.
Neotinker
(Ralph Schaffner)
16 Abril, 2019 14:44
9
