Addmob txt file
Hello! I want to add adMobile on my app for discourse but google want to add a file for example in : discourse.com/add-ads.txt and i dont know where to upload it. I need some help from someone that solved this problem before. Thanks!
Hello! Can someone help for a method to add a .txt file on mydiscourseurl.com/app-ads.txt
Is there anyone that can realise this because is very important for me.
I’m afraid you will need to build a plugin to do that.
@hawm thank you for your reply…
And you are telling me that there is no way to fix it in another method but just with plugin? I’m not capable to build a plugin.
It’s no other way to do that as i know. You may post to marketplace with some budget if you don’t konw about development, it won’t cost much for a simple plugin.
