Adjusting the size and alignment of text in my post
In the discussion “Adjusting the size and alignment of text in my post,” Mundobizarro asked how to increase the size of certain text in a post. pfaffman suggested using BBCode [size=xxx] tags by referencing the Discourse BBCode documentation.
Alternatively, jomaxro recommended using HTML <big>big</big> and <small>small</small> tags. awesomerobot mentioned that Discourse uses Markdown and provided a tutorial link, noting that headings can be created using # Heading 1, ## Heading 2, and ### Heading 3.
Mundobizarro found the # method helpful but then asked about center-aligning text or headings, which currently align left by default.
Hi,
I am looking for a way to increase the size of certain text in my post and I cant find it so far. Is there only one size possible for text?
Or how should i be able to edit this. Its my own forum btw i am the admin not sure if that matters.
Thanks in advance.
Luuk
You might check out Discourse BBCode. You can then use BBCode [size=xxx] tags.
Without any plugins you can also use HTML big and small to resize text.
Without any plugins you can also use HTML <big>big</big> and <small>small</small> to resize text.
Discourse also uses Markdown, you can find some reference and a tutorial explaining what you can do here:
The most common need for larger text is headings, which you can create like this:
# Heading 1
## Heading 2
### Heading 3
The above would output:
Heading 1
Heading 2
Heading 3
Thanks for all feedback! the # worked pretty easily
One more question.
Is it also possible to align my text or heading in the middle? It is now always on the left side but i would like to have this in the middle.
Thanks again!
