Admin/dashboard-next.json TypeError (no implicit conversion of Date into String)
I did splited the installation of my discourse from standalone into data and web containers with basically an new clean install and restore from backup.
After the restore was complete everything looks fine expect the dashboard, logs tells me:
TypeError (no implicit conversion of Date into String) /var/www/discourse/app/models/report.rb:290:in parse
Full stack trace:
/var/www/discourse/app/models/report.rb:290:in `parse'
/var/www/discourse/app/models/report.rb:290:in `block in report_time_to_first_response'
/var/www/discourse/app/models/report.rb:289:in `each'
/var/www/discourse/app/models/report.rb:289:in `report_time_to_first_response'
/var/www/discourse/app/models/report.rb:112:in `find'
/var/www/discourse/app/models/admin_dashboard_next_data.rb:40:in `block in reports'
/var/www/discourse/app/models/admin_dashboard_next_data.rb:40:in `map'
/var/www/discourse/app/models/admin_dashboard_next_data.rb:40:in `reports'
/var/www/discourse/app/models/admin_dashboard_next_data.rb:27:in `as_json'
/var/www/discourse/app/models/admin_dashboard_next_data.rb:18:in `fetch_stats'
/var/www/discourse/app/models/concerns/stats_cacheable.rb:26:in `refresh_stats'
/var/www/discourse/app/models/concerns/stats_cacheable.rb:21:in `fetch_cached_stats'
/var/www/discourse/app/controllers/admin/dashboard_next_controller.rb:5:in `index'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:194:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:132:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:41:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/rescue.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:134:in `process'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionview-5.2.0/lib/action_view/rendering.rb:32:in `process'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiling_methods.rb:104:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:191:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:252:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/mapper.rb:48:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:840:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-protection-2.0.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/tempfile_reaper.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/conditional_get.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/head.rb:12:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:200:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:98:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.2.9/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/executor.rb:14:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiler.rb:285:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/message_bus-2.1.5/lib/message_bus/rack/middleware.rb:63:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:186:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/engine.rb:524:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `<main>'
REQUEST_URI [/admin/dashboard-next.json?=1529489844854, /admin/dashboard-next.json?=1529489881799, /admin/dashboard-next.json?=1529489923985, /admin/dashboard-next.json, /admin/dashboard-next.json?=1529489981030, /admin/dashboard-next.json?_=1529490706651]
I tried to disable all plugins and rebuild to resolve this issue but it still persist.
「いいね!」 2
This seems like one of the recent commit has borked it!
I’m also stuck on a 500 while trying to access /admin
Same here!
This is definitely a bug:
For me, it has broke between after upgrading from 806f0ca to bb959e8
Only dashboard is non functional (new or old same story) rest all links work just fine.
Yes I have noticed it this morning. I will push a fix shortly. I don’t think it’s due to any recent change in the Dashboard though. It’s most probably caused by a very recent commit which is probably doing nothing wrong, but changed a little bit the behaviour in this case:
「いいね!」 4
@sam Before the patch the r variable discourse/app/models/report.rb at main · discourse/discourse · GitHub was:
{"hours"=>5.8700340581401, "date"=>"2018-05-21"}
After patch:
{"hours"=>5.8700340581401, "date"=>Mon, 21 May 2018}
I fixed it with FIX: crashes with date conversion in reports · discourse/discourse@fa43969 · GitHub as we don’t need Date parsing anymore since it’s already a Date.
「いいね!」 7
