dandv
(Dan Dascalescu)
15 فبراير 2017، 7:03ص
1
So there are two (at least, that I know of) plugins for displaying ads:
Summary
Discourse Advertising allows the set up of advertisements on Discourse
Install Guide
This plugin is bundled with Discourse core. There is no need to install the plugin separately.
AD-BLOCKERS If you are running an ad-blocker in your browser or through a vpn, the contents of your /admin/plugins page may be blanked out. Disabling your adblocker, using an incognito tab, or whitelisting your site should prevent this issue.
Features
https://meta.discourse.org/t/google-adsense-plugin/11763
Has anyone used both, and can compare? In particular,
SidV
15 فبراير 2017، 12:39م
I used both…
Both are awesome
The official has got more options for ads, the @michaeld ’s one is only for adsense.
The official do not break Discourse.
I do not use Michael’s now. But do not break my discourse either.
For ad placement, read the info for each plugin, both are great.
dandv
(Dan Dascalescu)
15 فبراير 2017، 7:58م
3
SidV:
Both are awesome
I don’t know about that. Michael’s plugin doesn’t support responsive ads and can’t show ads only on topics .
The official plugin doesn’t support responsive ads either, and can’t support displaying ads only to anonymous users, unless you hack the CSS to hide the ad (which means logged in users still waste time and bandwidth downloading the ad).
لا أعتقد أن هذا صحيح بعد الآن @neil ؟
neil
(Neil Lalonde)
15 يوليو 2019، 1:39ص
6
يدعم الإضافة الرسمي إعلانات AdSense المتجاوبة. لعرض الإعلانات على المستخدمين المجهولين فقط، يمكنك إضافة مستوى الثقة 0 (أي الجميع) إلى إعداد “لا إعلانات للمجموعة”.
