Neptun is experiencing an error while running rake db:migrate during a Discourse installation on a Debian 10 server with PHP 7.3.6 and Nginx. The error message reads: NoMethodError: undefined method 'keys' for nil:NilClass.
Rishabh points out that the guide being used is meant for development environments, not production servers, and suggests using the official Docker guides instead.
Neptun has tried using Docker, but encounters issues with ISPConfig and Discourse integration, resulting in broken styles and a blank page after admin registration.
Pfaffman suggests that running Discourse with ISPConfig may be difficult or impossible and recommends asking ISPConfig for help or using a separate server for Discourse.
Neptun has tried various solutions, including running without Docker, but still encounters the NoMethodError.
Pfaffman reiterates that ISPConfig is not supported by the Discourse community and advises against running a development installation for a production site, recommending instead to use a separate server or a cloud provider like DigitalOcean.
I had also searched for different guides or anything else at the web - but nothing found how to get this error fixed or how i could continue with the install.
I have also tried the docker install way - which was working at the setup - BUT it is not compatible with my used ISPConfig - discourse at subdomain get partial broken & after admin account registration, the wizard does not continue & always blank page anymore
About the “guide” was just to give an idea - as mentioned i have tried with the docker - but no chance to get it working correctly.
I have set up the reverse proxy and everything.
Setup was ok without issue BUT, Discourse get broken in style as well after admin registration only blank page & the wizard don’t start or continue - i have checked in database as well in the ruby app - admin account is/was active.
IspConfig tells me this is not related to their panel, it is an issue with Discourse - as well docker is not supported by IspConfig
I think the issue is regarding nginx vhost settings - but i don’t know which part i need to insert into the IspConfig control panel (similar as it is with other for example plesk - i have also read the postings here and tried different things)
There will be nothing special done as it is similar done by the default setup via docker
The assistance what i need is - what is the error what happens at db miration as mentioned above?
I cannot find anything in the web about it - and i would like to use discourse for my wordpress website what would be the perfect integration for comments & further support
If you have an idea how to get discourse working by docker & IspConfig - also perfect - it is my own server i can use in every way
The only issue in total is - i MUST install IspConfig before Discourse - because IspConfig needs the clean server for 100% clean working - first discourse with docker and then try to get IspConfig and the rest inside - not possible
It will be difficult and perhaps impossible to get it to work with ispconfig. If you want to run discourse with ispconfig you should ask ispconfig for help.
Ispconfig is not supported by the Discourse community.
No good can come from running a development installation for a production site. For $5/month you can just get a digital ocean droplet (or similar) and it will work.
