I followed this tutorial to replace the icons
I got the Android icons here
Material Symbols and Icons - Google Fonts
but when they replace they get misaligned like as in below example
How can I align them?
In a support discussion titled “After replacing icons I’m having trouble aligning them,” danielabc reports misalignment issues after replacing icons using Google Fonts’ Material Symbols. awesomerobot explains that Google’s SVGs include explicit height/width attributes, unlike FontAwesome’s, which rely solely on viewBox — causing sizing issues. The fix is to remove height/width from Google’s SVGs. However, danielabc finds some icons still misaligned even after removal. Further, danielabc notes that newly downloaded SVGs from Google Fonts no longer include viewBox attributes, which previously allowed easy fixes. Comparing old and new SVGs, danielabc confirms the missing viewBox is the culprit. awesomerobot suggests converting height/width into viewBox dimensions (e.g., viewBox="0 0 48 48") as a workaround. danielabc confirms this solution works and thanks awesomerobot for the help.
The easiest way to manage this will be to edit the icons themselves.
One factor I can see is that the icon set we use by default, FontAwesome, doesn’t include dimensions within their SVG files while Google does.
FontAwesome’s opening tag:
<svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 448 512">
Google’s (note the height and width added around the viewBox)
<svg xmlns="http://www.w3.org/2000/svg" height="48" viewBox="0 96 960 960" width="48">
So I’d try removing the height/width from Google’s icons… the resulting spritesheet looks like this:
<?xml version="1.0" encoding="UTF-8"?>
<svg xmlns="http://www.w3.org/2000/svg" style="display: none;">
<symbol id="google-bars" viewBox="0 96 960 960" ><path d="M150 816q-12.75 0-21.375-8.675-8.625-8.676-8.625-21.5 0-12.825 8.625-21.325T150 756h660q12.75 0 21.375 8.675 8.625 8.676 8.625 21.5 0 12.825-8.625 21.325T810 816H150Zm0-210q-12.75 0-21.375-8.675-8.625-8.676-8.625-21.5 0-12.825 8.625-21.325T150 546h660q12.75 0 21.375 8.675 8.625 8.676 8.625 21.5 0 12.825-8.625 21.325T810 606H150Zm0-210q-12.75 0-21.375-8.675-8.625-8.676-8.625-21.5 0-12.825 8.625-21.325T150 336h660q12.75 0 21.375 8.675 8.625 8.676 8.625 21.5 0 12.825-8.625 21.325T810 396H150Z"/></symbol>
</svg>
and the result is aligned ![]()
Thanks for helping me, I did it here and it worked, but there are some svg icons that even if I remove them, they are still big, like the ones below
<symbol id="baloon">
<svg xmlns="http://www.w3.org/2000/svg"><path d="M17.45 43.35v-10.4h-.8q-5.25.05-8.725-3.375Q4.45 26.15 4.45 21q0-5.15 3.575-8.75 3.575-3.6 8.725-3.6h3.2l-3.8-3.85 2-2.05 7.4 7.4-7.4 7.4-2-2.05 3.8-3.9h-3.2q-3.9 0-6.65 2.75Q7.35 17.1 7.35 21q0 4 2.775 6.7t6.725 2.7h3.5v5.9l5.95-5.9h5q3.9 0 6.65-2.75 2.75-2.75 2.75-6.7 0-3.9-2.775-6.65-2.775-2.75-6.675-2.75H29.5v-2.9h1.75q5.15 0 8.75 3.575 3.6 3.575 3.6 8.725 0 5.15-3.575 8.75-3.575 3.6-8.725 3.6h-3.75Z"/></svg>
</symbol>
<symbol id="points">
<svg xmlns="http://www.w3.org/2000/svg"><path d="M11.3 35.15q3.05-2.1 6.125-3.25T24 30.75q3.5 0 6.575 1.15t6.225 3.25q2.1-2.65 3.1-5.35 1-2.7 1-5.8 0-7.15-4.875-12.025T24 7.1q-7.15 0-12.025 4.875T7.1 24q0 3.1 1 5.8 1 2.7 3.2 5.35Zm12.7-9.4q-2.95 0-4.975-2.025Q17 21.7 17 18.75q0-2.95 2.025-4.975Q21.05 11.75 24 11.75q2.95 0 4.975 2.025Q31 15.8 31 18.75q0 2.95-2.025 4.975Q26.95 25.75 24 25.75Zm0 18.05q-4.1 0-7.675-1.55t-6.275-4.275q-2.7-2.725-4.275-6.3Q4.2 28.1 4.2 23.95q0-4 1.575-7.6 1.575-3.6 4.275-6.325t6.275-4.275Q19.9 4.2 24.05 4.2q4 0 7.6 1.575 3.6 1.575 6.3 4.275 2.7 2.7 4.275 6.3Q43.8 19.95 43.8 24q0 4.1-1.55 7.675t-4.275 6.275q-2.725 2.7-6.325 4.275Q28.05 43.8 24 43.8Zm0-2.9q2.7 0 5.35-.85 2.65-.85 5.1-2.8-2.4-1.75-5.075-2.65-2.675-.9-5.375-.9t-5.375.9q-2.675.9-5.025 2.65 2.4 1.95 5.05 2.8 2.65.85 5.35.85Zm0-18.1q1.75 0 2.9-1.15t1.15-2.9q0-1.75-1.15-2.9T24 14.7q-1.75 0-2.9 1.15t-1.15 2.9q0 1.75 1.15 2.9T24 22.8Zm0-4.05Zm0 18.5Z"/></svg>
</symbol>
do i have to take anything else to make it smaller?
I noticed now that if I download the svg icons from google fonts they no longer appear with the viewbox as they came before, why is that? would that have anything to do with it?
Before, the svg of the workspace icon was like this, with a view box (I just had to remove the height and width and everything was fine)
<svg xmlns="http://www.w3.org/2000/svg" height="48" viewBox="0 96 960 960" width="48"><path d="M230.693 931.614q-62.886 0-105.596-42.711-42.711-42.71-42.711-105.596 0-62.885 42.711-105.595 42.71-42.711 105.596-42.711 62.885 0 105.595 42.711 42.711 42.71 42.711 105.595 0 62.886-42.711 105.596-42.71 42.711-105.595 42.711Zm499.422 0q-62.693 0-105.596-42.711-42.903-42.71-42.903-105.596 0-62.885 42.903-105.595 42.903-42.711 105.596-42.711 62.693 0 105.404 42.711 42.711 42.71 42.711 105.595 0 62.886-42.711 105.596-42.711 42.711-105.404 42.711Zm-499.497-58.383q37.228 0 63.613-26.31 26.385-26.31 26.385-63.539 0-37.228-26.31-63.613-26.31-26.385-63.539-26.385-37.228 0-63.613 26.31-26.385 26.31-26.385 63.539 0 37.228 26.31 63.613 26.31 26.385 63.539 26.385Zm499.23 0q37.229 0 63.613-26.31 26.385-26.31 26.385-63.539 0-37.228-26.31-63.613-26.309-26.385-63.346-26.385-37.036 0-63.613 26.31Q640 746.004 640 783.233q0 37.228 26.48 63.613 26.481 26.385 63.368 26.385Zm-249.04-360.847q-62.693 0-105.596-42.903-42.903-42.903-42.903-105.596 0-62.693 42.903-105.404t105.596-42.711q62.693 0 105.403 42.711 42.711 42.711 42.711 105.404t-42.711 105.596q-42.71 42.903-105.403 42.903ZM480.54 454q37.229 0 63.614-26.48 26.385-26.481 26.385-63.368 0-37.229-26.31-63.613-26.31-26.385-63.346-26.385-37.037 0-63.614 26.31-26.577 26.309-26.577 63.346 0 37.036 26.481 63.613Q443.653 454 480.54 454Zm.075-89.923Zm249.308 419.23Zm-499.23 0Z"/></svg>
now it’s downloading like this, without a view box and it’s all big on the website
<svg xmlns="http://www.w3.org/2000/svg" height="48" width="48"><path d="M11.55 41.8q-3.15 0-5.3-2.15t-2.15-5.3q0-3.15 2.15-5.275 2.15-2.125 5.3-2.125t5.275 2.125Q18.95 31.2 18.95 34.35q0 3.15-2.125 5.3T11.55 41.8Zm24.95 0q-3.15 0-5.275-2.15-2.125-2.15-2.125-5.3t2.125-5.275Q33.35 26.95 36.5 26.95q3.15 0 5.275 2.125Q43.9 31.2 43.9 34.35q0 3.15-2.125 5.3T36.5 41.8Zm-24.95-2.95q1.85 0 3.175-1.3 1.325-1.3 1.325-3.2 0-1.85-1.325-3.175Q13.4 29.85 11.55 29.85q-1.85 0-3.175 1.325Q7.05 32.5 7.05 34.35q0 1.85 1.3 3.175 1.3 1.325 3.2 1.325Zm24.95 0q1.85 0 3.175-1.3Q41 36.25 41 34.35q0-1.85-1.325-3.175Q38.35 29.85 36.5 29.85q-1.85 0-3.175 1.325Q32 32.5 32 34.35q0 1.85 1.325 3.175Q34.65 38.85 36.5 38.85ZM24.05 20.8q-3.15 0-5.3-2.125T16.6 13.4q0-3.15 2.15-5.275Q20.9 6 24.05 6t5.275 2.125Q31.45 10.25 31.45 13.4q0 3.15-2.125 5.275Q27.2 20.8 24.05 20.8Zm0-2.9q1.85 0 3.175-1.325Q28.55 15.25 28.55 13.4q0-1.85-1.325-3.175Q25.9 8.9 24.05 8.9q-1.85 0-3.175 1.325Q19.55 11.55 19.55 13.4q0 1.85 1.325 3.175Q22.2 17.9 24.05 17.9Zm0-4.5ZM36.5 34.35Zm-24.95 0Z"/></svg>
Yes this might be causing some problems, strange that it was removed… I wonder if Google changed something? You can try moving the height/width to the viewbox values instead, that would look like:
<svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 48 48">
Now it works, thanks a lot for helping me!
