AI Helper stuck generating
MachineScholar reported that the AI Helper gets stuck on “generating” across all its options, despite the AI bot working normally. Their instance is up to date, and no error logs were initially visible. They’re using GPT-4o-mini via OpenAI (not Azure), which works fine for the bot but not the helper MachineScholar. The issue began a few days prior and remained consistent. A repeated error log showed: “Failed to open TCP connection to 2a00:116a:107:a220:::443 (Network is unreachable)” MachineScholar.
keegan asked whether the issue occurred in the composer, post menu, or both, and whether browser console logs revealed errors. MachineScholar confirmed the bug only affects the post menu (composer works), and shared console logs via PM. They also reported a new issue: in the composer, custom prompts default to the site’s locale (Polish) instead of the user’s preferred language (English), which keegan confirmed is intentional — per a 10-month-old policy that composer helpers use site locale, while post helpers use interface locale keegan.
After debugging via PM, keegan confirmed that updating the core and AI plugin resolved the “generating” freeze issue. The bug is now fixed.
For some reason, the AI helper is stuck on the “generating” window and never finishes, and this happens with each of the AI helper’s options. However, the AI bot works normally. I haven’t gotten any error logs from this either, so I can’t seem to isolate the issue. Thus this bug topic.
My instance is fully up to date.
What LLM / provider are you using?
GPT-4o-mini via OpenAI not Azure, however I’m using that exact same LLM for the AI bot which is responding normally.
I waited for 15 minutes but I couldn’t wait any longer so I have to assume that it would just continue on the generating page.
I only have this error from a few days ago. But the number of them hasn’t increased in a few days.
Message (22 copies reported)
Job exception: Failed to open TCP connection to 2a00:116a:107:a220:::443 (Network is unreachable - connect(2) for "2a00:116a:107:a220::" port 443)
Backtrace
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:1665:in `initialize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:1665:in `open'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:1665:in `block in connect'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/timeout-0.4.3/lib/timeout.rb:185:in `block in timeout'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/timeout-0.4.3/lib/timeout.rb:192:in `timeout'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:1663:in `connect'
/var/www/discourse/lib/final_destination/http.rb:27:in `block in connect'
/var/www/discourse/lib/final_destination/http.rb:17:in `each'
/var/www/discourse/lib/final_destination/http.rb:17:in `each_with_index'
/var/www/discourse/lib/final_destination/http.rb:17:in `connect'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:1642:in `do_start'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:1631:in `start'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:1070:in `start'
/var/www/discourse/lib/final_destination.rb:544:in `safe_session'
/var/www/discourse/lib/final_destination.rb:479:in `safe_get'
/var/www/discourse/lib/final_destination.rb:170:in `get'
/var/www/discourse/lib/retrieve_title.rb:94:in `fetch_title'
/var/www/discourse/lib/retrieve_title.rb:12:in `crawl'
/var/www/discourse/lib/inline_oneboxer.rb:76:in `lookup'
/var/www/discourse/lib/cooked_processor_mixin.rb:310:in `process_inline_onebox'
/var/www/discourse/lib/cooked_processor_mixin.rb:39:in `block in post_process_oneboxes'
/var/www/discourse/lib/oneboxer.rb:180:in `block in apply'
/var/www/discourse/lib/oneboxer.rb:128:in `block in each_onebox_link'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/nokogiri-1.18.7-x86_64-linux-gnu/lib/nokogiri/xml/node_set.rb:237:in `block in each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/nokogiri-1.18.7-x86_64-linux-gnu/lib/nokogiri/xml/node_set.rb:236:in `upto'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/nokogiri-1.18.7-x86_64-linux-gnu/lib/nokogiri/xml/node_set.rb:236:in `each'
/var/www/discourse/lib/oneboxer.rb:128:in `each_onebox_link'
/var/www/discourse/lib/oneboxer.rb:179:in `apply'
/var/www/discourse/lib/cooked_processor_mixin.rb:9:in `post_process_oneboxes'
/var/www/discourse/lib/cooked_post_processor.rb:44:in `block in post_process'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/lib/cooked_post_processor.rb:40:in `post_process'
/var/www/discourse/app/jobs/regular/process_post.rb:28:in `block in execute'
/var/www/discourse/app/jobs/regular/process_post.rb:8:in `execute'
/var/www/discourse/app/jobs/base.rb:316:in `block (2 levels) in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in `with_connection'
/var/www/discourse/app/jobs/base.rb:303:in `block in perform'
/var/www/discourse/app/jobs/base.rb:299:in `each'
/var/www/discourse/app/jobs/base.rb:299:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:220:in `execute_job'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:185:in `block (4 levels) in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:180:in `traverse'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:183:in `block in traverse'
/var/www/discourse/lib/sidekiq/pausable.rb:132:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:182:in `traverse'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job/interrupt_handler.rb:9:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:26:in `track'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:134:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:173:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:184:in `block (3 levels) in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:145:in `block (6 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_retry.rb:118:in `local'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:144:in `block (5 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/config.rb:39:in `block in <class:Config>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:139:in `block (4 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:281:in `stats'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:134:in `block (3 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_logger.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:133:in `block (2 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_retry.rb:85:in `global'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:132:in `block in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_logger.rb:40:in `prepare'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:131:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:183:in `block (2 levels) in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in `block in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in `process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:86:in `process_one'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:76:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/component.rb:10:in `watchdog'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/component.rb:19:in `block in safe_thread'
Is this happening for the AI helper in the composer, post menu or both? Do you see any error logs in your browser’s developer console while it’s stuck in “generating”?
I just checked, and I can confirm that it works in the composer so it is only stuck on generating in the post menu.
Yes!
May I PM you the log file? (Don’t want my site floating around here just yet)
:warning:
Furthermore, I have just noticed a new problem. When using the custom prompt on the selected in the composer, it automatically uses the Discourse instance’s default language (Polish) instead of the language I have set in my preferences (English). As observed in this screenshot:
(My custom prompt was “Turn this into a poem.”)
Yes feel free to PM me the log file, thanks!
Yes I believe this is intentional. About 10 months ago, we made the change to have composer helper use Site locale over the user’s interface locale:
And regarding the issue in the OP, I debugged this with @MachineScholar via PM and it turns out an update of core and AI plugin has resolved the issue :+1:
