תצוגה מקדימה של קישור אמזון עובדת כאן אבל לא בפורום שלי
Hello everyone,
I don’t understand why I don’t see the preview of the amazon links.
Here it works perfectly but in my forum that I updated today ( 9581d71372 ) it doesn’t.
Can it be cloudflare’s fault?
When you’re writing a post, do you see an error like this in the preview?
Screen Shot 2021-04-16 at 5.37.20 PM
There are some Amazon issues we’ve been running into where previews (oneboxes) have been hitting what seems to be a rate limit… we’ve made improvements in the past couple of weeks to try to avoid this, but it’s not completely solved and we’re looking for better options.
Thanks for your help Kris.
No, only a white box with Amazon
I also cleared the cloudflare cache.
PS. Here on meta works perfectly.
Sorry I forgot, this is the list of installed plugins.
I also tried on others Discorse forums and the preview doesn’t work, it only works here on meta :grin:
Nothing I give up … I have tried everything but I don’t understand what blocks the preview of the Amazon links.
OK I found other useful information, I am writing because it could be useful to someone…
The problem is the same:
If I run curl https://www.amazon.it/dp/B07YSF42TT -v -o deleteme I get error 503 so I give up.
Do you know if there is another way to add an image and a short description?
We get the same thing on our Discourse (v2.7.0.beta7( 42f6c9b6b9 )) when trying to share Amazon links:
And in the composer view:
I just put it down to never-ending Amazon issues.
Unfortunately no, I think your VPS is also blacklisted :frowning_face:
Sorry, yes, that’s what I meant :slight_smile:
Using curl -A "Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:59.0) Gecko/20100101 Firefox/59.0" https://www.amazon.it/dp/B07YSF42TT works fine, but now… how to change onebox useragent?
Also curl https://www.amazon.it/dp/B07YSF42TT -v -o deleteme -H "User-Agent: Discourse Forum Onebox v2.7.0.beta7" works.
> GET /dp/B07YSF42TT HTTP/2
> Host: www.amazon.it
> accept: */*
> user-agent: Discourse Forum Onebox v2.7.0.beta7
{ [5 bytes data]
* Connection state changed (MAX_CONCURRENT_STREAMS == 128)!
} [5 bytes data]
< HTTP/2 200
< content-type: text/html
< content-length: 7132
< server: Server
< date: Fri, 23 Apr 2021 07:17:05 GMT
< x-amz-rid: ZF2YDC7CWESPKSJ09DD0
< vary: Content-Type,Accept-Encoding,X-Amzn-CDN-Cache,X-Amzn-AX-Treatment,User-Agent
< strict-transport-security: max-age=47474747; includeSubDomains; preload
< x-cache: Miss from cloudfront
< via: 1.1 be8ca88bcfbe9f1ac2e2b6bb9e74f1d6.cloudfront.net (CloudFront)
< x-amz-cf-pop: MXP64-C2
< x-amz-cf-id: DfPapjMoZ5xW3vRm5sEk9bzKKmnq5TCDvbEi6y7dg6DreupmoWH2Jg==
{ [7132 bytes data]
100  7132  100  7132    0     0  78373      0 --:--:-- --:--:-- --:--:-- 78373
* Connection #0 to host www.amazon.it left intact
I don’t understand where I’m wrong…
OK, it only works with amazon.com
.es, fr, de, it and others don’t work, it’s definitely a bug!
Cat GIF
Hi all, I have updated to version 9ebc9541b9 and now the preview works on all amazon sites!
Thanks :blush:
Agreed!
This was the magic sauce that fixed it for us too:
https://github.com/discourse/discourse/pull/13173
Thanks @jbrw :bowing_man:t2:
I recommend a posts:rebake to generate the preview even the old messages.
./launcher enter app
rake posts:rebake
I would not recommend a rebake at all.
Amazon very will likely block your server IP address for hammering on their door.
We’ve been here, multiple times, with Amazon, YouTube and Instagram :confused:
