The discussion revolves around the idea of utilizing ScreenedURLs to block unwanted posts on a forum. Mittineague proposes adding URLs to a complete blacklist, where users are blocked and the post is not visible to anyone except moderators. However, codinghorror expresses concerns that this approach may be ineffective, as spammers often change URLs and IPs quickly.
Mittineague suggests an alternative approach of using keywords to block unwanted content. For example, a tech forum could block keywords like “louis vuitton” to prevent spam. Another idea proposed by Mittineague is to use the “banned words” feature, replacing URLs with asterisks to break the links.
Additionally, cpradio expresses support for blocking common URLs, such as adf.ly links, which are often annoying.
We found this was very ineffective at Stack. Urls are very easy to change and spammers rarely stick with one for long.
Not opposed to it, but unlikely to help much, if at all.
For common urls you just don’t like or don’t ever want posted , those are more stable and can work. Like if you decide you dislike sports so much you don’t ever want a link from ESPN.com posted, ever. Or the craptacular w3schools.
[quote=“codinghorror, post:2, topic:22219”]
For common urls you just don’t like or don’t ever want posted , those are more stable and can work. [/quote]
Yes please. Particularly so we can block adf.ly links. Those are annoying as all get out.
It’s true enough that both everchanging IPs and URLs get used.
Maybe a better approach would be “keywords” which depending on the forum would be different.
eg. “louis vuitton” would work for a tech forum but not a handbag forum.
