Seems like my discourse site is using a pretty aggressive “AND” semantics, such that if I have (for example) 5 documents which contain either ‘foo’ or ‘bar’, but only one which contains ‘foo bar’, and I search for ‘foo bar’ (no quotes) I get only the one page, where I’d like to see that one first, but then also see the others in some kind of descending order (relevance or recency or whatever). I can’t see a way through the Advanced Search page or otherwise to specify that the terms should be logically OR’d, however. Advice?
There is no way to do this at the current time.
That’s unfortunate, but thanks for the quick response.
