I am trying to write a script with a cron that can automatically restore my backup from s3 weekly.
So it can run every sunday instead of me going in UI and restore it. (Our site’s restore takes a couple hour…)
Did anybody do anything similar?
jimmy0017 is seeking a script to automatically restore backups from S3 weekly for a test site, allowing experimentation without manual intervention. merefield questions the frequency, to which jimmy0017 clarifies it’s for testing purposes. elmuerte suggests using an isolated Docker container for restore tests, ensuring no external communication. pfaffman provides a command to restore the latest backup, suggesting to use cron for scheduling.
Why do you need to restore so frequently?
Is your site corrupting on a weekly basis?
This is for a test-site. So i can try experimenting settings/things.
To check if the backups are actually ok? Did you know most people do not actually perform restore tests.
If I would do this, I would spin up a isolated docker container to restore the backup. This docker container would be destroyed after a successful restore. This new container would not be allowed to communicate to the outside world (e.g. not send any emails, not download new content, etc.).
Restoring a backup could be a simple docker exec with the commands
discourse enable_restore
discourse restore <backup>.tar.gz
But you need the same container image for the site to verify… So maybe a image rebuild after the restore? and then verify.
docker exec app bash -c '$(discourse restore | grep discourse|head -1)'
will restore the latest backup. Then you’d just get chron to run it when you want.
