これらの行をコメントアウトしないと、すべてのビルドが失敗します。もちろん、その場合SSLは設定されません。
昨日までは正常に動作していました。
Lets Encrypt (https) を追加する場合は、これら 2 行のコメントを解除してください
“templates/web.ssl.template.yml”
“templates/web.letsencrypt.ssl.template.yml”
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/replace_command.rb:20:in `eval': (eval at /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/replace_command.rb:20):1: unknown regexp options - lcal (SyntaxError)
/usr/local/bin/configure-ssl
(eval at /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/replace_command.rb:20):2: unknown regexp options - lcal
exec /usr/local/bin/configure-letsencrypt
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/replace_command.rb:20:in `guess_replace_type'
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/replace_command.rb:10:in `from_hash'
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/command.rb:10:in `run'
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/config.rb:239:in `block (2 levels) in run_commands'
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/config.rb:223:in `each'
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/config.rb:223:in `block in run_commands'
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/config.rb:222:in `each'
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/config.rb:222:in `run_commands'
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/config.rb:203:in `run'
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/lib/pups/cli.rb:96:in `run'
from /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.4.0/bin/pups:9:in `<required>':
from /usr/local/bin/pups:25:in `load'
from /usr/local/bin/pups:25:in `<main>'
