- # frozen_string_literal: true
- # name: poll
- # about: Official poll plugin for Discourse
- # version: 1.0
- # authors: Vikhyat Korrapati (vikhyat), Régis Hanol (zogstrip)
- # url: https://github.com/discourse/discourse/tree/main/plugins/poll
- register_asset "stylesheets/common/poll.scss"
- register_asset "stylesheets/common/poll-ui-builder.scss"
- register_asset "stylesheets/desktop/poll-ui-builder.scss", :desktop
- register_asset "stylesheets/common/poll-breakdown.scss"
- register_svg_icon "far-square-check"
- enabled_site_setting :poll_enabled
- module ::DiscoursePoll
- PLUGIN_NAME = "poll"
- end
- require_relative "lib/poll/engine"
- after_initialize do
- require_relative "app/controllers/discourse_poll/polls_controller"
- require_relative "app/models/poll_option"
- require_relative "app/models/poll_vote"
- require_relative "app/models/poll"
- require_relative "app/serializers/poll_option_serializer"
- require_relative "app/serializers/poll_serializer"
- require_relative "jobs/regular/close_poll"
- require_relative "lib/poll"
- require_relative "lib/ranked_choice"
- require_relative "lib/polls_updater"
- require_relative "lib/polls_validator"
- require_relative "lib/post_validator"
- require_relative "lib/post_extension"
- require_relative "lib/user_extension"
- Discourse::Application.routes.append { mount DiscoursePoll::Engine, at: "/polls" }
- allow_new_queued_post_payload_attribute("is_poll")
- register_post_custom_field_type(DiscoursePoll::HAS_POLLS, :boolean)
- topic_view_post_custom_fields_allowlister { [DiscoursePoll::HAS_POLLS] }
- reloadable_patch do
- Post.prepend(DiscoursePoll::PostExtension)
- User.prepend(DiscoursePoll::UserExtension)
- end
- validate(:post, :validate_polls) do |force = nil|
- return unless self.raw_changed? || force
- validator = DiscoursePoll::PollsValidator.new(self)
- return unless (polls = validator.validate_polls)
- return if polls.blank? && self.id.blank?
- if polls.present?
- validator = DiscoursePoll::PostValidator.new(self)
- return unless validator.validate_post
- end
- # are we updating a post?
- if self.id.present?
- return if polls.blank? && ::Poll.where(post: self).empty?
- DiscoursePoll::PollsUpdater.update(self, polls)
- else
- self.extracted_polls = polls
- end
- true
- end
- NewPostManager.add_handler(1) do |manager|
- post = Post.new(raw: manager.args[:raw])
- if !DiscoursePoll::PollsValidator.new(post).validate_polls
- result = NewPostResult.new(:poll, false)
- post.errors.full_messages.each { |message| result.add_error(message) }
- result
- else
- manager.args["is_poll"] = true
- nil
- end
- end
- on(:approved_post) do |queued_post, created_post|
- created_post.validate_polls(true) if queued_post.payload["is_poll"]
- end
- on(:reduce_cooked) do |fragment, post|
- if post.nil? || post.trashed?
- fragment.css(".poll, [data-poll-name]").each(&:remove)
- else
- post_url = post.full_url
- fragment
- .css(".poll, [data-poll-name]")
- .each do |poll|
- poll.replace "<p><a href='#{post_url}'>#{I18n.t("poll.email.link_to_poll")}</a></p>"
- end
- end
- end
- on(:reduce_excerpt) do |doc, options|
- post = options[:post]
- replacement =
- if post&.url.present?
- "<a href='#{UrlHelper.normalized_encode(post.url)}'>#{I18n.t("poll.poll")}</a>"
- else
- I18n.t("poll.poll")
- end
- doc.css("div.poll").each { |poll| poll.replace(replacement) }
- end
- on(:post_created) do |post, _opts, user|
- guardian = Guardian.new(user)
- DiscoursePoll::Poll.schedule_jobs(post)
- next if post.is_first_post?
- next if post.custom_fields[DiscoursePoll::HAS_POLLS].blank?
- polls =
- ActiveModel::ArraySerializer.new(
- post.polls,
- each_serializer: PollSerializer,
- root: false,
- scope: guardian,
- ).as_json
- post.publish_message!("/polls/#{post.topic_id}", post_id: post.id, polls: polls)
- end
- on(:merging_users) do |source_user, target_user|
- DB.exec(<<-SQL, source_user_id: source_user.id, target_user_id: target_user.id)
- DELETE FROM poll_votes
- WHERE user_id = :source_user_id
- AND EXISTS (
- SELECT 1
- FROM poll_votes
- WHERE user_id = :target_user_id
- AND poll_votes.poll_id = poll_votes.poll_id
- UPDATE poll_votes
- SET user_id = :target_user_id
- WHERE user_id = :source_user_id;
- SQL
- end
- add_to_class(:topic_view, :polls) do
- @polls ||=
- begin
- polls = {}
- post_with_polls =
- @post_custom_fields.each_with_object([]) do |fields, obj|
- obj << fields[0] if fields[1][DiscoursePoll::HAS_POLLS]
- end
- if post_with_polls.present?
- all_polls = Poll.includes(:poll_options).where(post_id: post_with_polls)
- Poll.preload!(all_polls, user_id: @user&.id)
- DiscoursePoll::Poll.preload_serialized_voters!(all_polls)
- all_polls.each do |p|
- polls[p.post_id] ||= []
- polls[p.post_id] << p
- end
- end
- polls
- end
- end
- add_to_serializer(:current_user, :can_create_poll) do
- scope.user&.staff? || scope.user&.in_any_groups?(SiteSetting.poll_create_allowed_groups_map)
- end
- add_to_class(PostSerializer, :preloaded_polls) do
- @preloaded_polls ||=
- if @topic_view.present?
- @topic_view.polls[object.id]
- else
- Poll.includes(:poll_options).where(post: object)
- end
- end
- add_to_serializer(:post, :polls, include_condition: -> { preloaded_polls.present? }) do
- preloaded_polls.map { |p| PollSerializer.new(p, root: false, scope: self.scope) }
- end
- :post,
- :polls_votes,
- include_condition: -> do
- scope.user&.id.present? && preloaded_polls.present? &&
- preloaded_polls.any? { |p| p.has_voted?(scope.user) }
- end,
- ) do
- preloaded_polls
- .map do |poll|
- if poll.ranked_choice?
- user_poll_votes =
- poll
- .poll_votes
- .where(user_id: scope.user.id)
- .joins(:poll_option)
- .pluck("poll_options.digest", "poll_votes.rank")
- .map { |digest, rank| { digest: digest, rank: rank } }
- else
- user_poll_votes =
- poll
- .poll_votes
- .pluck("poll_options.digest")
- end
- [poll.name, user_poll_votes]
- end
- .to_h
- end
- register_search_advanced_filter(/in:polls/) do |posts, match|
- if SiteSetting.poll_enabled
- posts.joins(:polls)
- else
- posts
- end
- end
- end
This file has been truncated. show original
