11117
(Владислав Левин)
12 أبريل 2019، 2:49م
1
Hello,
Is there a way to fetch all users so the result for each one contains the external id ?
Didn’t find this on API documentation page, but maybe i missed something
Falco
(Falco)
12 أبريل 2019، 4:17م
Did you try the export in the Admin > Users page?
11117
(Владислав Левин)
15 أبريل 2019، 10:20ص
3
Thank you for the reply! It works.
So, there is no way to do this using api request, only by Discourse UI ?
zogstrip
(Régis HANOL)
7 مايو 2019، 9:22ص
4
Everything you do with the UI can be done via the API.
Discourse is backed by a complete JSON api. Anything you can do on the site you can also do using the JSON api.
The API is documented at docs.discourse.org . You can also use the discourse_api Ruby gem as a client library. However, not every endpoint is documented.
To determine how to do something with the JSON API here are some steps you can follow.
Example: recategorize a topic.
Go to a topic and start editing a category:
[image]
Open Chrome dev tools, switch to the Network tab, select …
