I´m trying to add a group to a category via the api using postman.
Is there a way to do that ?
The discussion revolves around using the Discourse API to modify category group permissions. Edwin_Silva seeks to assign a group to a category via API, initially struggling with incorrect request setup in Postman. David advises on proper API usage, emphasizing the need to use x-www-form-urlencoded parameters and inspect the correct PUT request (e.g., /categories/192) when saving changes. Mikechristopher shares a working method using form data and confirms that specifying the group name in the permissions[group_name] field works. Edwin_Silva confirms success. Slim follows up, asking whether it’s possible to add a single group permission to an existing category without redefining all permissions, noting that omitting existing groups causes errors. The thread highlights the importance of correct parameter formatting and understanding how permissions are applied in the API.
Yes, everything in Discourse has an API. You can learn the API endpoints for stuff you see in the UI using Reverse engineer the Discourse API
Isn’t there a other way to do it ?
I’m trying to assign a group to a category, so only people in that group can see this category.
I know that there are some similar questions out there, where you can reverse engineer DIscourse.
I want to change the marked property on the picture
In the second picture you can see what i tried inside postman
The number used in the request i got from trying to reverse engineer it as seen in the last picture
Did I make some mistake in my put request?
The _ parameter isn’t actually required - it is just there as a “cache buster”. You can remove it.
Also, you are looking at the incorrect request in your developer tools. You should be looking at the request that happens when you click the “save” button. (You will need to tick “preserve log” in dev tools so that the request doesn’t dissappear when the page reloads). Look for a PUT request to /categories/192.
Another thing to watch out for is that your parameters need to be urlencoded. In postman, you do this by changing from “form-data” to “x-www-form-urlencoded”.
Hope that helps get you a little bit closer!
Thanks for the reply.
I can´t seem to find the right request
You should not be using the “raw” option on postman
Does it work?
And do you call your group name “1” ?
no the name of the group goes in the [groupname] section
It does work - I use that exact set up all the time.
So I could write permissons[random grop name]?
works for me - as long as the group exists of course first.
I will try that later. Thanks for the replay
It worked. Thanks man. You a lifesaver
Hi @Edwin_Silva and @mikechristopher
I’m trying to apply the lessons here, but failing.
In my case, instead of CREATING a category with group access, I’m ADDING a group to an EXISTING category.
When I apply the lessons above, I get an error saying that the subcategories don’t have access to their parent category.
If I specify a permissions[group_name] for every single group name that the category already has, then I don’t get an error. So I at least know what the problem is. It think I’m setting just one permission and removing the rest.
Now I’m wondering if it’s possible to just add ONE new group permission without having to set the entire permission set.
Would you be willing to help?
slim
